soldering fumes and general electronics benchwork..
2005-02-07 by Steve
for "fume extraction" I use a little 12v black computer type fan with
a wallwart and switch soldered up.. just blows the fumes away.  works
for me and these things are available as surplus everywhere for very
cheap...
I was wondering what everyone does for wire strippers..  I have a few
pairs of the super simple cheap pliers type where you hope to not cut
the wire off as you cut through the insulation and hopefully strip
off just the insulation..
so Ive got this type...
http://www.surplustronics.co.nz/image/TT0108.jpg
whats better, any recommendations?
thanks
~Steve
Re: [motm] soldering fumes and general electronics benchwork..
2005-02-08 by Richard Brewster
I have a small desktop air filter, a Walmart type product, that I turn
on to blow solder fumes away.
Wire stripping is a skill you can learn.  A good tool helps, but it's
the skill more than the tool.  I strip wires with a tool similar to the
one you linked.  Mine is yellow, has straight, rather than curved
handles, and has no spring.  (The spring can fatigue your hand.)  It's
permanently set to a #24 gauge but I strip everything including coax
with it.  I work under a magnifier, so I can see the details clearly.  I
use two hands, one holding the wire, the other the stripper.  I sense
the depth of the cut and pressure needed.  I've learned to be careful
and also to tolerate a little nick here and there.  It doesn't have to
be perfect because it's not avionics (which I actually did a long time
ago).  If you nick too much, take a new wire.  I've tried all sorts of
strippers over the years, but always come back to the little hand tool.
Large strippers that grip the insulation are ungainly, don't fit in a
tight space, and tend to damage the insulation.  You can hand craft
better with a light, little tool.  The trick is to find a good one.
There are a lot of cheap units out there.  These are inexpensive enough
to buy several until you find one that works well.  It should operate
smoothly, and be comfortable in your hand.  I've been using the same
stripper for 25 years!   Insulation doesn't dull the cutting edge.
Of course if you are building a MOTM kit, you don't need to strip
wires!  Paul spoils you.
-Richard Brewster
>cheap...
>thanks
>~Steve
RE: [motm] soldering fumes and general electronics benchwork..
2005-02-08 by Greg James
I been drinking about this fuming concussion and conluded that they
are all fillaments of your imoogination. I like the smell and snuff it
very chance I get. Maskes MTOM boards come out sounding better too.
My sillyscope looks cool too.
That Jay, he's aa hooter aint he?
bye bye
Re: soldering fumes and general electronics benchwork..
2005-02-08 by Steve
Well, i've been using the small handy dandy type (as in the previous
link) for years and have no problems using them for everything like
you mention..  I was just wondering if there is something better that
is simple like these and also versatile and cheap..  I found it!!
today at Home Depot of all places..  for $7.50,  one similar to this
style:
http://www.botron.com/functions/functions/images/B0924WEBLG.jpg
the ones I got are real small (yay) and strip in the perfect range
for synth work (16-26 ga) They work great. . just squeeze and pull!
cool, a notch for every gague.
anyway...
carry on carrying on
~Steve
turn
it's
It's
coax
clearly.  I
sense
careful
to
time
of
tool.
a
one.
enough
operate
same
> -Richard Brewster
2005-02-08 by Mike Estee
> cheap...
The best wire stripper I've ever used:
http://tools.tycoelectronics.com/autwirstrip.html
It auto calibrates for whatever you put in it. Just pick the depth and
pull the trigger.
Wire stripping WAS: fumes and workbench..
2005-02-08 by J. Larry Hendry
I've sent this link before, but it has been a while.  I use these:
http://larry.retrosynth.com/larry/misc/strip_1.jpg
http://larry.retrosynth.com/larry/misc/strip_2.jpg
Sweet. Insert wire (notice adjustable strip gauge stop).
Squeeze.  One motion holds wire, cuts, and strips off insulation.
Larry H
