StonZ assembly hint
2005-01-18 by John Blacet
When it comes time to mount the PCB to the bracket to the front panel, it helps to know which of those wires coming off the solder side of the PCB go into which slot in the bracket. (It also helps to have three hands -- but a bit of patience will win out). The four wires from J4, 5, 6, 7 go through the *bottom* front slot. The rest of the wires, except for the three obvious wires that go way to the rear of the PCB, go through the *upper* front slot. -- Regards, John Blacet Blacet Research http://www.blacet.com
