MOTM-440 pix posted
MOTM-440 pix posted
2005-01-03 by Paul Schreiber
Thanks to D. Brown, here is a good shot of an assembled MOTM-440:
www.synthtech.com/misc/motm440.jpg
Re: [motm] MOTM-440 pix posted
2005-01-04 by Jeff Laity
Thanks, everyone, for your on- and off-list responses. It looks like
the 440 has a higher part count, and many of these parts are multi-pin
ICs. There appears to a temperature-regulation resistor on there as
well. I was worried that I needed an oscilloscope to set it up or
something like the 300 osc modules. As I said, I'll probably end up
with both anyway, so perhaps I should just start with the simpler one
so I don't get discouraged. I've built a few DIY projects before,
though, and some of them even work!
Paul, does this kit use vintage/out of production SSM parts? Maybe
that's another reason to hold off on the project: I wouldn't want to
smoke one of the last remaining SSM chips.
I can hear the difference between Dotcom and MOTM – if I couldn't, I
wouldn't even consider MOTM. The price difference seems to be about
3:2, so the question is either more modules or better modules. But if
I'm not going to build the best-sounding modular synth out there, why
do it at all? :)
>  Paul S.
2005-01-04 by Paul Schreiber
a) You don't need a 'scope to build/calibrate the '440. THere is a 1V/OCT trim, if you set it to the center you will be within 10% tracking, and then set by ear (at self-resonance).
b) No CEM/SSM synth ICs are used in the current modules. The ancient and highly collectible MOTM-110 did use a CEM3330, but that was the only one (replaced by the MOTM-190). The SSM2210/2220 parts that ARE used are not "synth ICs", they are just 2 transistors in a package that *looks* like an IC and are in current production by Analog Devices.
2005-01-04 by Mike Estee
> something like
Oh, that part is easy. The most difficult  part about MOTM assemble is
keeping in mind that there are parts you can wash, and parts you can't
(and a different solder for each kind.) Just don't mess those up and
your ok.
As a tip: I insert all my resistors and axial caps before I do the
first solder. This way when I'm picking parts if I find that one
doesn't match that probably means there's another one that doesn't
match elsewhere. It's a lot easier to fix misplaced parts *before* you
solder them down.
Another tip: presort your resistors. I presort all like resistors out
into their own piles before assembling. It makes the whole process go a
*lot* faster, and reduces errors.
> the 300 osc modules. As I said, I'll probably end up with both anyway,
> so perhaps I should just start with the simpler one so I don't get
> discouraged. I've built a few DIY projects before, though, and some of
> them even work!
> do it at all? :)
Another interesting observation: MOTM synths maintain there value
*very* well. It all depends on the soldering skills of the assembler of
course, but as a general rule used modules are worth the same as new
ones. Keep that in mind when you're putting your modules together, take
your time! Double check your work, and work in phases to reduce error
(i.e. take a frickin' break!)
Does anyone know of any online soldering resources for beginners? I
know of this one: http://www.circuittechctr.com/guides/guides.shtml
If someone wants to host it, I'll record a video of assembling a MOTM
300.
--mikes
