Archive for motm.
OT - Old gear, old capacitors
2004-12-19 by ivancu@aol.com
Paul - A while ago you said the following regarding going through old gear before you power it up:
"Next, if you see ANY green disc-type bypass caps, replace them with AVX or Kemet 0.1 axial parts. These have a history of shorting out."
Is this just a standard AVX or Kemet ceramic disk capacitor? I'm guessing 50V? Do you have a specific part number you recommend for this application?
Thanks!
Ivan
Re: [motm] OT - Old gear, old capacitors
2004-12-19 by Paul Schreiber
NOT a disc cap! The axial caps used as MOTM bypass caps.
Repeat after me: disc caps bad. Axial caps good!
MOTM uses Kemet part number C410C104M5U5CA7200 which is parts on a 'reel'. (the
A7200 at the end, I think).
To: <motm@yahoogroups.com>
Sent: Saturday, December 18, 2004 10:41 PM
Subject: [motm] OT - Old gear, old capacitors
> Thanks!
> Ivan
