FS: RME ADI-8 AE, A/D-D/A converters
2004-11-20 by Eric Frampton
FS: RME ADI-8 AE converters
I know this is not strictly on-topic, but I thought y'all might
appreciate the heads-up. Watch your replies, this is cross-posted.
limited edition version of the ADI-8 DS with slightly lesser converter
IC's. 24 bit 96K A-D/D-A converters. TDIF, ADAT Lightpipe I/O. Bit
splitting or double-speed.
Excellent-to-mint condition with box and manuals. I'm only getting rid
of it because I just don't use it much anymore, and other tools beckon.
There aren't too many around (1500, to be exact), and I'm not really
sure of their current value. Let's start at $1000 + shipping + Paypal
(cashier's check or MO is OK too) and if that's way off the mark
somebody kindly let me know.
Eric Frampton, keyboards     Atlanta, Georgia, USA
http://www.ericframpton.com
StonZ MOTM front panel
2004-11-20 by John Blacet
Some folks wanted to see the Front Panel:
http://www.blacet.com/MOTMfp.pdf
Sorry about the PDF; something is awry in converting CAD to jpg.
John Blacet
Blacet Research
Re: [motm] StonZ MOTM front panel
2004-11-20 by Tentochi
Regen CV is in the wrong place.  It needs to go on the right at the bottom.
Also, the pots appear to be spaced too far apart.
You should strongly consider having Moe design and Stooge Industries manufacture.
Remember that MOTMers are a different market than than Frac Rackers.
--Shemp
Do you Yahoo!?
The all-new My Yahoo! - Get yours free!
http://my.yahoo.com
The Regen was moved at the suggestion of "a Stooge" because the legend
was too close to the Mod Mix Legend. Looked like crap.
Actually the new position makes more sense as the Regen pot, switch and
CV input are now in a vertical row.
The pots are correctly spaced.
> bottom.
> manufacture.
> --Shemp
> Do you Yahoo!?
> http://my.yahoo.com
> Yahoo! Groups Sponsor
> <http://us.ard.yahoo.com/SIG=129a1jo52/M=296572.5585671.6651487.3001176/D=grplch/S=1705032277:HM/EXP=1101065928/A=2343726/R=0/SIG=12i6ne3e8/*http://clk.atdmt.com/VON/go/yhxxxvon01900091von/direct/01/&time=1100979528385294>
> Get unlimited calls to
> U.S./Canada
> <http://us.ard.yahoo.com/SIG=129a1jo52/M=296572.5585671.6651487.3001176/D=grplch/S=1705032277:HM/EXP=1101065928/A=2343726/R=1/SIG=12i6ne3e8/*http://clk.atdmt.com/VON/go/yhxxxvon01900091von/direct/01/&time=1100979528385294>
>     * To visit your group on the web, go to:
>       http://groups.yahoo.com/group/motm/
>     * To unsubscribe from this group, send an email to:
>       motm-unsubscribe@yahoogroups.com
>       <mailto:motm-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
John Blacet
Blacet Research
Re: StonZ MOTM front panel
2004-11-20 by Dana Countryman
Gee, all I see in the pdf file is BLACK.
Anybody else have this problem?
I'm really interested in this module - I *love* the sound in the first
mp3 demo...
Help!
 - Dana
--- In motm@yahoogroups.com, John Blacet <blacet@b...>
because the legend
pot, switch and
> > bottom.
Industries
> > manufacture.
Frac Rackers.
> > --Shemp
to jpg.
> > Do you Yahoo!?
> > http://my.yahoo.com
> > U.S./Canada
> > Yahoo! Groups Links
scribe>
Terms of
> Regards,
> John Blacet
> Blacet Research
2004-11-20 by J. Larry Hendry
I figured it was too late in the PCB process to move the control.  So,
getting the jacks out from underneath it made sense.  Maybe everyone does
not agree.  It sure frees up more room to add the text "LFO" and "EXT."
However, there is now room for the "0" which is missing.  Maybe "LFO" and
"EXT" can now go below or the "0" and "10."  What do you think?
I would have picked a slightly differnet jack arrangement with the bottom
row being the IN, EXT MOD, and OUTs with the CVs grouped together in the
other 3 spots.  My only rational for that is the convention that is normally
found on MOTM panels.
Larry H
To: MOTM
Sent: Saturday, November 20, 2004 3:24 PM
Subject: Re: [motm] StonZ MOTM front panel
The Regen was moved at the suggestion of "a Stooge" because the legend was
Actually the new position makes more sense as the Regen pot, switch and CV
manufacture.
--Shemp
Do you Yahoo!?
http://my.yahoo.com
John Blacet
Blacet Research
U.S./Canada
Yahoo! Groups Links
Re: [motm] Re: StonZ MOTM front panel
> From: Dana Countryman <dana@...>
I had some issues with the PDF file, but I was able to open it and extract a
JPEG, and size it up for easy viewing.
Here is John's panel converted to JPG:
http://www.wiseguysynth.com/larry/blacet/MOTMfp.jpg
Here is another slightly different version with the last little tweaks I
mentioned.
http://www.wiseguysynth.com/larry/blacet/MOTMfp_reva.jpg
The files are not linked from anywhere other than this e-mail.  John, I'll
remove them when people have had a chance to see them, or sooner if you ask.
Best,
Larry H
2004-11-21 by John Blacet
"0" added back and "LFO", "EXT" moved. The jack arrangement is a
compromise to avoid renumbering the jacks on all the other Blacet
documentation and PCB and thus having to provide duplicates in the
manual. I'm trying to keep the process doable for future products.
> normally
> Larry H
> From: John Blacet
> To: MOTM
> bottom.
> manufacture.
> --Shemp
> Do you Yahoo!?
> http://my.yahoo.com
> Regards,
> John Blacet
> Blacet Research
> U.S./Canada
> ADVERTISEMENT
> click here
> <http://us.ard.yahoo.com/SIG=129t5uhit/M=298184.5584357.6650215.3001176/D=grplch/S=1705032277:HM/EXP=1101074131/A=2434971/R=0/SIG=11eeoolb0/*http://www.netflix.com/Default?mqso=60185400>
John Blacet
Blacet Research
I've replaced the PDF with a jpg. This is a different file conversion program, so hopefully this will work for everyone.
For you Mac OSX users, the program that has been the problem is "Preview". It does not like to convert pict into jpg. And apparently it does something funny with the pict to PDF conversion although some folks are gettting a black picture.
John Blacet
Blacet Research
John Blacet
Blacet Research
