One more cable clarification
2004-10-19 by J. Larry Hendry
The default on MOTM logo cables is for the heat shrink to be on the inside of the barrel. You have to tell me if you want it on the outside. The default connector on the MOTM logo cables is the two stripe P-280 switch craft look a like. The Neutrik single stripe with the word Neutrik stamped in it is also available. You have to ask for it. The only 1/4" connector available on Wise Guy solid color cables is the Neutrik with the single stripe. I'm working to change that in the future. Cables with any 3.5 mm ends (one or both) will be solid color Wise Guy cables. The translucent vendor does not offer 3.5 mm connectors on their cables. As always, send questions my way Larry
