adding 5V power to existing system
2004-10-16 by groovyshaman@snet.net
I wanted to confirm a few things:
1)
pin 1 = +15
pin 2 = GND
pin 3 = GND
pin 4 = -15
pin 5 = digital GND
pin 6 = +5V
is the correct spec for the new MTA-156 power connector.
2) I have two supplies, a 5V and a +-15V. The grounds of the two supplies
should be connected together as close to the supplies as possible.
3) 12AWG or 14AWG?
4) Once completed, crack open beer.
George
Re: [motm] adding 5V power to existing system
2004-10-16 by Paul Schreiber
Correct all down the line. Especially the beer part.
To: "motm group" <motm@yahoogroups.com>
Sent: Saturday, October 16, 2004 10:05 AM
Subject: [motm] adding 5V power to existing system
> 1)
> pin 1 = +15
> pin 2 = GND
> pin 3 = GND
> pin 4 = -15
> pin 5 = digital GND
> pin 6 = +5V
> 3) 12AWG or 14AWG?
> George
2004-10-16 by J. Larry Hendry
I'm going to add a couple of comments:
There is little difference between 12 and 14 AWG. I used 12 where I could
get what I wanted and 14 where I had to. In the 5 row cabinet shown at
AHMW, one supply was used to feed all distribution boards. Voltage drop to
the most distant distribution PCB = 0.01 volts.
For triple voltage supplies run two ground wires from the PCB to the power
supply common connection -- one from the already common on the PCB 15V
grounds and a separate wire from the digital ground. I hate calling these
grounds. To me they are neutrals (sometimes called common on the power
supplies). Whatever you call the wire, you need 2 of them, connected
together at the power supply end and NOT at the PCB end.
If you have separate supplies, bond the cases, and connect both cases to
earth ground only of the incoming AC cable. This is separate from any and
all DC grounds.
I will add power supply wiring to my "order of the universe" list. I
learned these in life (mostly by screwing them up):
Life planning rule:
Correct order:
1. School
2. Marriage
3. Babies
Incorrect order:
all others
House buying property rule:
Correct order:
1. Road
2. House
3. Creek
Incorrect order (my house):
1. Road
2. Creek (with bridge)
3. House
Power supplies:
Correct order:
1. wiring
2. testing
3. beer
Incorrect order:
beer first
Larry, still just a Stooge who got his most recent college degree while his
kids were already in college.
> 1)
> pin 1 = +15
> pin 2 = GND
> pin 3 = GND
> pin 4 = -15
> pin 5 = digital GND
> pin 6 = +5V
> 3) 12AWG or 14AWG?
> George
Yahoo! Groups Links
Heh - thanks guys. Beer is on ice until job is complete. One other
thing.. any good links to cheap 12/14AWG wire? This crap is expensive!
George
PS: Larry, your Life Planning Rule is so 80s! :)
Sent: Saturday, October 16, 2004 11:42 AM
Subject: Re: [motm] adding 5V power to existing system
> From: Paul Schreiber <synth1@...>
> Paul S.
> From: J. Larry Hendry <jlarryh@...>
could
to
power
these
and
> all DC grounds.
> Life planning rule:
> Correct order:
> 1. School
> 2. Marriage
> 3. Babies
> Incorrect order:
> all others
> Correct order:
> 1. Road
> 2. House
> 3. Creek
> 1. Road
> 3. House
> Power supplies:
> Correct order:
> 1. wiring
> 2. testing
> 3. beer
> Incorrect order:
> beer first
his
> From: <groovyshaman@...>
> > 1)
> > pin 1 = +15
> > pin 2 = GND
> > pin 3 = GND
> > pin 4 = -15
> > pin 5 = digital GND
> > pin 6 = +5V
supplies
> > 3) 12AWG or 14AWG?
> > George
RE: [motm] adding 5V power to existing system
2004-10-16 by John Loffink
The quickest and cheapest source for 12/14 AWG wire is your local auto parts
store. You can also find most of the FAST-ON type connectors there.
John Loffink
> -----Original Message-----
> From: groovyshaman@... [mailto:groovyshaman@...]
> Sent: Saturday, October 16, 2004 3:04 PM
> To: motm group
> George
2004-10-17 by Richard Brewster
Yup. Got my power supply distribution wire at Advance Auto Parts.
Maybe I'm just paranoid, but I don't trust hand-crimped spade lugs. I
crimp by hand and then solder 'em. If I had an industrial quality crimp
tool I might have a different outlook. All I have is the "squeeze hard
and hope for a good connection" kind.
-Richard Brewster
>John Loffink
>>To: motm group
>>George
