MOTM-510 clarification
2004-10-10 by Paul Schreiber
The FULL OUT of the MOTM-510 is *always* a positive voltage. If fact, if you
look at the wave with a scope you can see this, and also it will clip at ground.
The AUDIO OUT is AC coupled, so you will get +-swings.
I should have put this in the manual, I will add it.
