Any Binary Zone users?
2004-10-04 by earthtodylan2000
Larry Stooge is about to drill my panel for my Binary Zone to
MOTM faceplate.
What do you all use for the pushbutton? I need to give him a
hole mesurement pronto.
Many thanks,
DSS
Standard Button (was Re: [motm] Any Binary Zone users?)
2004-10-04 by Tentochi
Moe had originally proposed a button (E-Switch)about 4 or 5 years ago.
Since then I finally got Paul to make a comment or two about a "standard" pushbutton. Working
with him, I came up with a new "standard" button. It is the NKK SB4011NOH. You can use it as it
or it comes with a variety of colored slip-on caps you can put on it.
The cool thing is that Moe's originally button and this one both take the same hole size: 1/2".
SB4011NOH OD: 0.492"
Max. panel thickness: 0.157"
Paul liked this switch because it is NKK the same as the standard MOTM toggle switch and because
it is lower profile than some other switches. He also suggested the SB series for some reason,
but I can't remember what is was now....
As a general reminder for those drilling their own panels, Moe's excellent drilling guide can be
found here: http://hotrodmotm.com/drill_howto.htm.
I have some pictures of the bushbutton if any one would like to post them or just take a look.
Cheers!
Shemp
Do you Yahoo!?
Yahoo! Mail Address AutoComplete - You start. We finish.
http://promotions.yahoo.com/new_mail
