FW: [motm] Rear Mounted Power Supply
2004-09-28 by Tkacs, Ken
Scott, you should really consider insulating that switch handle...
<g>
Scott's system is so big he needs a special switch to turn all of those
power supplies on at the same time. It's a rather big knifeblade (about
70
lbs worth).
http://www.midiwall.com/wall/switch/sw_002.jpg
<snicker>
Stooge Larry
<g>
70
lbs worth).
<snicker>
Stooge Larry
At 2:24 AM +0000 2004/09/28, black_man_music wrote:
>I serached the archives and didn't quite find an answer to my
>question, which is...
>If I mount my power supply in the back and I cannot access the
>switch, is it OK to turn off/
>on the system using my Furman AR-1215 voltage regulator? Thanks!!
Yes. I have several cabinets with rear mounted power supplies all
plugged into one power bar. I use the switch on the power bar to turn
the whole thing on and off.
