some newbie questions for the pros
2004-09-28 by Wood
as some of you may know from my recent posts i just
completed my 420 filter. i really likr the way it sounds but had some questions
about a few things. i have a mostly roland setup analog wise and plan on
using my mc202 and sh101 to trigger this thing. do i have to send it a gate
signal or would a trigger from an 808 or 909 work as well? i also have access to
a juno6 but dont know if i can do anything with that and havent tried. paul
said the cv changes the resonance setting, will a trigger signal change this to
the new value instantaneously or can i get a gradual change? how do you guys
like to use your 420 filter? i am also planning on ordering another module soon
and would like to hear any suggestions you may have. i will only be able to get
a module once every four to five months so i am thinking i will stick with
things i can use with the stuff i already have (signal processing type modules
to run my exsisting gear into). i will want to eventually start building up to a
standard synth voice but i think i would prefer to get things i can use
immediately than build something like that over the course of a year or so. when
i finish school in two years i will be able to buy modules more frequently and
will not be so limited, also once i get a few more modules i may be just fine
with the idea of building something i cant use right away. any way sorry for the
dumb questions and i really appreciate any help and ideas or advice you can
provide me with.
thank you, eric
