Rear Mounted Power Supply
2004-09-28 by black_man_music
I serached the archives and didn't quite find an answer to my question, which is...
If I mount my power supply in the back and I cannot access the switch, is it OK to turn off/
on the system using my Furman AR-1215 voltage regulator? Thanks!!
RE: [motm] Rear Mounted Power Supply
2004-09-28 by John Loffink
Yes.
John Loffink
> -----Original Message-----
> From: black_man_music [mailto:black_man_music@...]
> which is...
> it OK to turn off/
Re: Rear Mounted Power Supply
2004-09-28 by mate_stubb
I don't even have a power switch for the supplies in the Synth of Doom...
Go for it!
Moe
http://www.hotrodmotm.com
--- In motm@yahoogroups.com, "black_man_music" <black_man_music@y...>
Re: [motm] Rear Mounted Power Supply
2004-09-28 by Scott Juskiw
Yes. I have several cabinets with rear mounted power supplies all
plugged into one power bar. I use the switch on the power bar to turn
the whole thing on and off.
2004-09-28 by J. Larry Hendry
Scott's system is so big he needs a special switch to turn all of those
power supplies on at the same time. It's a rather big knifeblade (about 70
lbs worth).
http://www.midiwall.com/wall/switch/sw_002.jpg
<snicker>
Stooge Larry
Yahoo! Groups Links
