Rare String Filter - jpeg
2004-09-23 by elhardt@att.net
Because of past talk about the Moog String filter and related stuff and Juergen Haible building a string filter, I figured I'd post an ad to an unknown string filter that I cut out of an ancient Contemporary Keyboard issue decades ago. According to somebody on I think the Virus list from a few years ago, only one was ever made and he ended up with it. Unfortunately he wasn't using it for its intended purposes but as a distortion unit he said. What a wasteful use of an interesting piece of gear. So here is probably the only time you'll ever see a picture of one in your life:
http://home.att.net/~elhardt/Formula_Sound_String_Filter.jpg
Each filter has a 3 position switch under it, not sure what they do. I can only make out two of the knob labels, which looks like MODE on the 2nd knob, and RESONANCE SHIFT on the 4th.
-Elhardt
Re: [motm] Rare String Filter - jpeg
2004-09-23 by jhaible@debitel.net
>your life:
Hi Ken and list,
the picture is too small to really tell anything, but my guess is that
the Faders (obviously) give individual attenuation for each band, and the
3-position switches either
(a) make a hard panning of each channel to left / center / right
or
(b) switch each band on (in phase)/ off / on (phase inversion).
That's the two things I'd consider interesting, at least.
JH.
debitel.net Webmail
Re: Rare String Filter - jpeg
2004-09-23 by ivancu2
Formula Sound is an existing company in the UK that makes mostly
high-end DJ mixers. Might be the same company:
http://www.formula-sound.com/
The font used for the filter company name looks very similar to this
company. Might be worth an e-mail.
Ivan
