Juskiw MOTM-830 mod?
2004-09-12 by ixqy@aol.com
Hi all,
 I finally got around to doing the unity gain mod as described on Scott
Juskiw's site:
http://www.tellun.com/motm/mods/motm830/motm830.html
 After replacing the resistors, I spent a good hour+ troubleshooting an
oscillation that was being output from the OUT1 jack. I didn't find any solder
splashes, or anything else physically wrong, so I reinstalled the original
resistor at R18 (100K). The oscillation problem went away, but so did unity gain
increase from inputs 4, 5, and 6 to OUT1.
 So, any ideas what might be the cause of this problem? Do I have a bad
OP285, or is will changing the value of C1 help?
 Thanks for any ideas,
 Andrew Sanchez
Re: [motm] Juskiw MOTM-830 mod?
Okay, my problem is solved. Note to self: Never misread mod info to read
49.9 ohms when it really reads 49.9K ohms. Zoinks! Thanks to Larry Hendry for
helping me out.
 Over and out,
 Andrew
In a message dated 9/11/04 9:34:29 PM Central Daylight Time, ixqy@...
writes:
>  Juskiw's site:
> solder
unity
> gain
