Panning VCAs
2004-09-11 by Richard Brewster
Hello all, I have been experimenting with two-channel stereo panning and wanted to share my thoughts and get yours. My 1980's era homebrew Electronotes synth used a pair of EN linear VCAs, for which I provided a panning VC input. That did some convenient internal voltage conversion. All the VCAs I use are similar to the MOTM-190 in taking a control voltage in the range of zero to +5V, with zero volts equating to zero gain and +5V to unity gain. (I have two 190 VCAs, a modified Blacet Quad VCA/Mixer, and a Quad Low Pass Gates. The latter is yet to be built, but I will calibrate it for a five volt control range.) Let's say we want to pan a signal from left to right in stereo. We need two VCAs, both taking the same signal input, with one going to the left and the other the right channel output. We want to smoothly pan from one side to the other and back. Stands to reason that we need one control going from zero to five as the other goes from five to zero volts. Now my first problem is how to get a five to zero volt signal, starting from a zero to five volt one. I can't just use an inverter, because the result will be going zero to minus five. I have to add an offset of five volts. In my synth I have several ways to do this. I modified my MOTM-800 EGs so that the minus output goes from +5 to zero. (Hint: It takes one resistor.) So I could use an 800. But the exponential wave shape may not always be what I want for panning. Another module I can use is one of my Blacet EG2070s. These also have + and - outputs like the MOTM-800. The Blacet by design goes from +5V to zero on the minus output. The upper voltage is adjustable, because Blacet standard VCA controls are zero to +10V. I adjust mine for the five volt range to match MOTM. The Blacet EG is a linear device and can self-cycle, so I have a pretty good panning controller there. But what if I need my Blacet EG for something else? A third candidate is my super-custom MOTM-OMS-820, which I modified to add a zero to +5V self cycle mode. Again, that is way overkill for this purpose. *I just want an LFO that goes zero to +5V!* Blacet's new LFO has zero to 10V and 10V to zero outputs. It is built for panning the Blacet VCAs. But I don't have one of those LFOs! And if I did, I would have to modify it for a five volt range. Back to my 1980's synth. The panning input took a zero to five volt signal and did the conversion internally. I've seen many VCA panners with this feature. I suspect the long-awaited MOTM panning VCA has it. That's not the end of it. For proper panning you want a smooth transition of the sound field. It should appear to be moving gracefully left to right, without extreme level changes. This requires the right sort of response in the VCA and the right control contour. I've been playing with different combinations. Using a sine wave as the control with an exponential VCA response seemed pretty good. (That takes a MOTM-320R and two of my Mixer-Comparator modules to rig up.) I'm over my head here and just dabbling. Surely some of you folks know a lot more about this. I haven't researched my Electronotes archive yet on this one (I tend to drop those heavy binders on my toes!). So what do you folks use for VC panning? Cheers, Richard Brewster
