MOTM Trivia
MOTM Trivia
2004-09-07 by Tentochi
Time for more MOTM trivia! I have put forth a few questions like this in the past.
Who proposed the original name for MOTM (Hint: It was a women.)?
When was it proposed?
What were the original initials that were proposed?
What was the *initial* form factor MOTM was based on (Hint: It was not the final decision.)?
What was the planned first module called? What functions would be on board (Hint: It never went
into production.)?
What noted synth personality helped design the VCO?
I will leave it at that for now.
Cheers!
Shemp
Do you Yahoo!?
Read only the mail you want - Yahoo! Mail SpamGuard.
http://promotions.yahoo.com/new_mail
Re: [motm] MOTM Trivia
2004-09-08 by David Moylan
When do we get the answers? I've been waiting a _whole_day_ :)
>into production.)?
>Cheers!
>Shemp
>Do you Yahoo!?
>Yahoo! Groups Links
MOTM Trivia ==> ANSWERS
2004-09-08 by Tentochi
Here they are!!!
Dan Higdon's wife
September 10, 1997 (publicly, perhaps a day or two before privately)
MoM
Digisound
> went into production.)?
"General Purpose Processing Module"
* precision sample/hold
* noise generator
* ring modulator with built-in mic pre-amp
* undedicated VCA
Doug Curtis (although I don't know to what degree). I don't know if any of the fruit of this
joint effort ended up in the MOTM-300 or not ultimately. I do know *A LOT* of ideas were kicked
around and the initial limited-run design was CEM3340 based (later discarded).
--Shemp
Do you Yahoo!?
New and Improved Yahoo! Mail - Send 10MB messages!
2004-09-09 by Paul Schreiber
Actually, a more correct answer is Doug Kraul. He was a contributor of
Electronotes, and did the pcb layout for the '300. The design is based (in part)
from a EMu Systems 1200 VCO "submodule" reversed engineered by Charlie Thompson.
Doug, Charlie and I all worked together at Data General in Austin TX in
1979-1980.
MOTM Trivia ==> ANSWERS (repost)
2004-09-09 by Tentochi
Here they are!!!
Dan Higdon's wife
MoM
Digisound
* noise generator
* undedicated VCA
--Shemp
Do you Yahoo!?
Yahoo! Mail Address AutoComplete - You start. We finish.
