synced LFO patch help
2004-08-29 by David Moylan
Hi all. Hoping someone help me figure out a way to set up this patch.
I want to use a 320 as a clock but have it synced to a second slower
clock. No problem, but I'd like to also get a pulse out when the sync
hits. Basically, so the sync pulse indicates beat 1 and the LFO then
outputs clock pulses of some other timing.
Two ideas that come to mind:
1. Using the shape to set the pulse width really wide, so that the sync
pulse is very likely to cause a hi-lo transition. Then i'd need to
invert the pulse out?
2. Hacking the 320 so the the sync pulse from U2B is diode OR'd with
the output of U6B to the pulse out jack.
What'd'ya think?
Dave
What'd'ya think?
Dave
