Opinions Sought: BBE Sonic Maximizer
2004-08-21 by mbedtom
I would appreciate hearing from everyone out there in MOTM-land who
has experience with a BBE Sonic Maximizer.  Seems like a one-trick
pony but if the trick is good, it might be justified.  Is the plug-in
version sonically equivalent to the "external box" version?  The plug-
in is cheaper and might help keep noise levels down...
Your thoughts on this and anything related, would be most appreciated.
Cheers!
Tom Farrand
Re: Opinions Sought: BBE Sonic Maximizer
2004-08-21 by mate_stubb
I used to work at a music store where we would regularly play with the
external box version. It works well on full spectrum mixes. I'd
imagine that it would also be good for adding high end clarity to
things, maybe synthesizing cymbals and such. I have no experience with
the plugin.
Moe
> Cheers!
> Tom Farrand
Re: [motm] Opinions Sought: BBE Sonic Maximizer
2004-08-21 by Paul Haneberg
I have one of these in my studio (hardware).  I use it on my far field
monitors.  It does seem to tighten up the high end and improve the clarity
of the sound.  If you are using it with an equalizer as I am (an Ashley
Stereo 31 band) I found that I had to change the equalizer settings after I
installed the BBE.  Although it is supposed to improve imaging etc. through
offsetting phase shifts it also definitely adds an equalization effect.
Though I can't really say that the EQ effect isn't caused by the phase
compensation.  In any case it's not just psychoacoustic as my RTA can see
the EQ change as well.
I also used these things when I was in the live sound business.  They really
improve live sound a lot IMHO.  Interestingly enough. if I use the BBE on my
near-field monitors, some very expensive Genelecs, the BBE seemed to reduce
the quality of the sound rather than improve it.  Possibly the Genelecs do
not need any phase compensation.  I've been thinking of putting one on my
home stereo to see if it improves the sound.
I have no experience with the software version, but the hardware version is
definitely worth the money as far as I'm concerned.
To: <motm@yahoogroups.com>
Sent: Saturday, August 21, 2004 2:18 AM
Subject: [motm] Opinions Sought: BBE Sonic Maximizer
> Cheers!
> Tom Farrand
2004-08-21 by Mike Marsh
That's kind of a tough one.  It does obvious things to the track,
sometimes good sometimes not.  It's good to have in the arsenal, but
I don't use it on everything.  The bass extension you can get is
really good, though.  Note that I've never used it on analog tracks,
just VA.
I use the plug-in.
Mike
who
in
plug-
appreciated.
> Cheers!
> Tom Farrand
I should have mentioned that I use Izotope's Ozone now on just about
every final mix.  It gives a much more detailed final product than
BBE.  Of course it's more expensive, but in my opinion this is THE
secret weapon in mixdown technology.
Mike
I have a friend that uses a BBE (hardware) in his guitar rig and
will not play live without it!
m
but
tracks,
> just VA.
> I use the plug-in.
> Mike
> who
trick
plug-
> in
> plug-
> appreciated.
> > Cheers!
> > Tom Farrand
2004-08-21 by ivancu@aol.com
>>I would appreciate hearing from everyone out there in MOTM-land who has experience with a BBE Sonic Maximizer.<<
I personally don't care too much for the BBE Sonic Maximizer.  The Aphex Aural Exciter is a step above it but still is a similar concept.  Personally, to "enhance" an instrument or a mix I prefer the SPL Vitalizer family of products.  Much more flexible in my opinion.  It is less of an effect and more of a tool.  Just my opinion; your mileage may vary.
Ivan
2004-08-21 by Scott Juskiw
I bought a hardware BBE Sonic Maximizer specifically for a project
involving cassette to CD remastering. It did wonders to brighten up
the sound on 20 year old cassettes. I also tried the plug-in version
and it sounded quite similar to the hardware version. I haven't had
any need to use it on any other projects, but I intend to keep if
forever.
I suppose that if you always record sound into a computer before
processing, then the plug-in version would work for you. But if you
need any live processing, then the hardware box is the way to go.
2004-08-22 by ivancu@aol.com
>From: "Paul Haneberg" <phaneber@...>
>Interestingly enough. if I use the BBE on my near-field >monitors, some very expensive Genelecs, the BBE seemed to reduce
Same with sound reinforcements systems.  The BBE effect is very pleasant and noticeable with really bad sound reinforcement speakers systems (Bose and such that use a lot of EQ to attempt to widen frequency response are particularly "enhanced" by the BBE).  But in a very high quality sound reinforcement system the BBE effect can be quite annoying.  Same with studio monitors.
Ivan
2004-08-24 by Jim Black
This is the reason I bought one back circa '88... then
found out it wasn't half bad on sampled kick drums.
Like lo-fi sampled kick drums that need tightening.
Like anything, I guess it has its merits, but overuse
is a very bad thing.
> for a project
> to brighten up
Do you Yahoo!?
Yahoo! Mail - 50x more storage than other providers!
http://promotions.yahoo.com/new_mail
