Cynthia Euro'Dapter Cards
2004-08-13 by Cynthia Webster
> Message: 1 > Date: Thu, 12 Aug 2004 20:27:54 -0000 > From: "elherbus" <jvasche@...> > Subject: Analogue Systems to MOTM format? > > Hi everyone, > > How difficult is it to convert AS modules to MOTM format? (I'm > intrigued by the RS310 reverb/chorus...) I assume that in addition > to the wiring for pots and jacks I would have to change the power > connector, but I don't know what else would be involved. Looking at > their website, it doesn't appear that the modules are offered as > kits, only preassembled. Is this going to be a huge headache? I have a custom circuit board designed specifically for this called the Cynthia Euro'Dapter Card. It has a combination of mechanical and electronic courtesies that make my custom module adaptations to Modcan & Cynthia format a breeze! They' work just fine for MOTM Panels as well! It is 2x6 inch card with a pair of 12 volt regulators, and a 5 volt regulator, and converts the board mounted 4-pin MOTM/Blacet/Oakley/EFM/Encore power connector with (+/- 15 VDC) to the Analogue Systems type power connector with (+/- 12 VDC and 5 VDC). It also has power connectors for Doepfer, Analog Sys, Analog Sol, Modcan, Serge, and Arrick so it is really a universal module transporter board. I have about (4) fully assembled cards still in stock at $60.00 each (includes shipping in the USA). They are fairly simple, but all the hard work is done for you! I will try to get a page of pictures up quickly, and can provide any number of these if you want to pre-order them. (See, I read this list too! LOL!) Best Wishes! Cynthia
