VC Divider opinion
VC Divider opinion
2004-08-07 by Paul Schreiber
Yes, I'm blowing the dust off the VC Pulse Divider project today (sorry, I need
a diversion from kitting/shipping/soldering/endless loop). Also, I have had over
$600 in parts I bought for it sitting in the closet for 3 years now :)
There is an 8-step output (3 bit counter into a DAC), and I can select 3
different scalings via panel toggle switch. Here is what I have sketched in
there now:
#1: steps are 1V, so we "step in octaves"
#2: steps are 1/12th volt, so we "step in ...errr. whole steps"
#3: steps are 3/12th volt, so we "step in 3rds"
Any other suggestions? I plan to use 0.1% resistors here to get quite accurate
(trying to have no trims).
The counter has a panel switch to select either the CLK IN or the /N to drive
it.
For newbies: this module can simultaneously divide an input by /2 to /32 or /1.5
to /32.5 (the variable /N which *is* voltage controlled) along with "fixed"
outputs of /2.../9 & /16). I'm whipping up a breadboard for Robert Rich to use
on the new CD. It uses 2 PIC controllers and has a nice 3-digit LED display. I'm
*guessing* the kit price is in the $239 area. Has a LOT of jacks (like 17?) The
outputs are 0 to +5V square waves at 50% duty cycle, so they can be used as
audio OR triggers into EGs, etc.
RE: [motm] VC Divider opinion
2004-08-07 by John Loffink
#3 - step in 7/12 of a volt, to step in fifths.
John Loffink
> -----Original Message-----
> From: Paul Schreiber [mailto:synth1@...]
> Sent: Saturday, August 07, 2004 11:48 AM
> To: MOTM litserv
> Subject: [motm] VC Divider opinion
> need
> had over
> in
> there now:
> accurate
> drive
> it.
> or /1.5
> "fixed"
> use
> display. I'm
> 17?) The
> as
> Paul S.
Re: [motm] VC Divider opinion
2004-08-07 by ixqy@aol.com
Paul writes:
 Wouldn't that would be half steps? :-)
 Andrew
Re: VC Divider opinion
2004-08-07 by Mike Marsh
#4 - step in 5/12 for fourths
> John Loffink
> > From: Paul Schreiber [mailto:synth1@a...]
> > To: MOTM litserv
(sorry, I
> > need
have
> > had over
select 3
sketched
> > in
> > there now:
> > accurate
/N to
> > drive
> > it.
to /32
> > or /1.5
> > "fixed"
Rich to
> > use
> > display. I'm
> > 17?) The
be used
> > as
> > Paul S.
> > Yahoo! Groups Links
> Paul writes:
Bleh....not enough Dr. Pepper. Correct.
BTW: is 1.3rs or fifths more "useful"?
2004-08-07 by Scott Juskiw
Most useful (in order):
1. octaves
2. fifths
3. fourths
4. minor thirds
5. major thirds
6. whole step
7. half step
8. everything else
Re: [motm] Re: VC Divider opinion
2004-08-07 by Robert van der Kamp
Second that, both 4ths and 5ths would be great.
- Robert
2004-08-07 by jwbarlow@aol.com
I find I use the VC Divider a lot for clocking an analog sequencer. Being
able to subdivide by 2 to say 32 is quite useful. Having a really fast pulse
train and toggling frequently between different subdivisions can create really
interesting rhythms.
I hope this can be kept in mind while developing this module.
JB
I'm going to start with oct/4th/5ths with a resistor table for the 'real' one to
put in whatever you want :)
Just finished the schematic. Off to basketball game, then I'll lay the pcb out
(it's 1/2 autorouted, which will route in about 4 seconds).
This stepped output goes 'up' only. There is also a RESET input that zeros the
divider/stepped out.
It's a cute design, IMHO.
2004-08-08 by John Loffink
Agreed.
John Loffink
> From: Scott Juskiw [mailto:scott@...]
> Sent: Saturday, August 07, 2004 1:13 PM
> To: motm@yahoogroups.com
> Subject: Re: [motm] VC Divider opinion
> 1. octaves
> 2. fifths
> 3. fourths
> 4. minor thirds
> 5. major thirds
> 6. whole step
> 7. half step
> 8. everything else
2004-08-08 by Robert van der Kamp
> > 1. octaves
> > 2. fifths
> > 3. fourths
> > 4. minor thirds
> > 5. major thirds
> > 6. whole step
> > 7. half step
> > 8. everything else
Same here. Nice list.
- Robert
2004-08-11 by Richard Brewster
If the output square waves go +/-5V instead of 0 to +5V, then they can
be inverted by any analog inverter.  I find this useful to produce both
phases for control purposes.  If you invert 0 to +5V you get 0 to -5V,
which can't be used as a gate or trigger.
-Richard Brewster
>Paul S.
2004-08-11 by Paul Schreiber
Errr...not going to put 16 level shifters on there! Over 180 parts just for
that!
finishing up pc board for the breadboard *today*
Yes, I can certainly understand that!  For DIYers who would like to add
this feature to any module, check out the PC board Ken Stone made for
this purpose at my request.  Go to http://www.cgs.synth.net/ and look
for the CGS56 PC board, Gate Converter.  It has 4 converters built
around a TL074 chip.  The board is 1.15 x 2 inches in size.  Four of
these boards would be needed for Paul's VC Divider (assuming 16
outputs).  The CGS56 could be put to other uses, as well.
-Richard Brewster
>that!
>Paul S.
