YASDWB
YASDWB
2004-08-07 by Paul Schreiber
Yet another SuperDigital WhizBang
www.kontron.com
look at the DIMM-PC/LITE, and entire 100Mhz, '486 computer the size of a
business card. About $89ea in 100pcs.
going digital this weekend (just a silly phase, not to panic) :)
Re: YASDWB
2004-08-07 by charlesosthelder
<sigh> I guess this is better than going postal.  Still, I think to
myself, "8 years of college for *this*?!"
Chub - deeply analog
> www.kontron.com
size of a
> Paul S.
Re: [motm] Re: YASDWB
I suppose part of it is recalling I paid $6700 for a Zeos 386 case/motherboard,
1 floppy, a Video7 VGA card (first card that could really do 1024 x 768), a
120MB drive and a NEC monitor (the monitor alone was $1500).
The Micronix motherboard was all *through-hole* 22V10 PALs. I counted like 140
of them (other motherboards used chip sets from Chips and Technologies). The
motherboard alone (no processor) pulled 34A at +5V. I paid like $299 for a Cyrix
387 math co-processor and this was "a great deal". Ah, the good old days.....
RE: [motm] Re: YASDWB
2004-08-07 by Bob Colwell
Back in the 1980's, the entire industry's TTL, at least in the DIP packages, became buggy due to ground bounce.
At a minisupercomputer startup called Multiflow, we were trying to ship large machines with thousands of FAST
and Advanced Schottky TTL chips that were all screwed up because of the lead inductance inside the packages.
We eventually discovered that 22V10's were properly designed, didn't suffer much if any ground bounce, and
could be programmed to do a lot of what the entire rest of the TTL line did. So if you look inside any Multiflow
machines (think museums here) you'll see a lot of those 22V10's. Not to mention you could fix design flaws
after the fact, which otherwise required wires tack-soldered to the PCB's.
Old days indeed...-BobC
74Fxxx logic *never* worked. I think many TTL design carrers were derailed by
those awful things.
The VC Pulse Divider will have 74ABT244 drivers on the outputs. Hardly any
ground bounce at all (ground bounce  causes severe under-shoot in TTL edges).
2004-08-07 by John Loffink
John Loffink
Off Topic, but 74FXXX did work.  You just needed separate ground and power
planes and serious decoupling, virtually requiring 4 layer boards which
weren't all that common back then.
ABT and other recent logic is much better today.
Early Altera CPLDs were worse for ground bounce than F chips.  On the early
600, 900 1200 series Altera was recommending gray code counters (only 1 bit
transitions at a time) because their chips couldn't handle transition of an
8 bit counter from 11111111 to 00000000 without internal glitching.
I found a similar problem on a 1990ish AMI/Gould PLD.  Data glitch was
pattern sensitive.  I had to trace circuitry through half a dozen full
height racks to solve that one.  Switched to a similar Lattic part - problem
solved.
John Loffink
> -----Original Message-----
> From: Paul Schreiber [mailto:synth1@...]
> Sent: Saturday, August 07, 2004 11:37 AM
> To: motm@yahoogroups.com; Bob Colwell
> Subject: Re: [motm] Re: YASDWB
> by
> those awful things.
> edges).
> Paul S.
Re: YASDWB
2004-08-07 by Mike Marsh
Uh, what CV Pulse Divider?
derailed by
> those awful things.
Hardly any
TTL edges).
> Paul S.
Re: YASDWB
Never mind, i reead the later posts which I should have done before
posting this one...
> derailed by
> > those awful things.
> Hardly any
> TTL edges).
> > Paul S.
