I have an 8 channel bus made out of 2.5m of unbalanced multicore going
from a patchbay to a 1U panel on my modular. This has proven invaluable
for several reasons:
• no more cables (hm, fewer..) pulled across the studio from the
modular to my patchbay.
• the routing is flexible I can get to/from mixer/modular *real* quick.
i.e. take a send from the console patch it to the bus, patch out of the
bus to a filter etc. back into the bus and then into a channel on the
mixer.
• as I have a few monosynths perched on/around my modular I use this
bus as their I/O as well. Makes for easier integration of
monosynth-modular fun.
• I start to think of my modular as a real extension to my mix
environment rather than an extra device. I've even started using
patches as inserts on channels.
I suppose these things are obvious to most folks but they were a
quantum leap for my productivity and modular use.
ad
On Aug 4, 2004, at 17:44 Uhr, Mike Marsh wrote:
> This is pretty much my setup, too. Very flexible. I tweak the
> input trim of the mixer as needed...
> Mike
> --- In motm@yahoogroups.com, Scott Juskiw <scott@t...> wrote:
>> I have four cables into my mixing board dedicated to my modular.
>> Sometimes these will patch into the output of a VCA, sometimes
>> they'll be patched to the output of a filter, or to the output of
> a
>> frequency shifter. Sometimes I'll have to run a few extra cables
> from
>> the modular to the mixer if the patch has more than four distinct
>> sounds that I want to record on separate tracks.
>> Some time ago, there was talk from texas about an output module,
> but
>> that seems a bit superfluous if you have a mixing board.
>>> Hey, as I wait for my first box o'modules to show up I thought
> I'd toss
>>> out a question: what's your connection from your MOTM to the
> rest of
>>> your gear?
>>> That got me wondering what everyone else was using.
> Specifically, what
>>> module do you patch out of (VCA? something else?) and what do you
> connect
>>> into (preamp? mixing board? A/D?)
_____________________
Receive-Transmit
Marienburgerstr. 33
VH EG rechts
10405 Berlin
Germany
Receive-Transmit
Marienburgerstr. 33
VH EG rechts
10405 Berlin
Germany
Mobile +49 179.750.1854
Office +49 030.255.627.94
Fax +49 030.255.627.96
