Yikes!
2004-06-24 by Overand
So my MOTM-300 started wandering... a lot. I said 'crap, I assembled something wrong.' Checked solder joints, parts, etc, and I discovered that it was a 'mechanical' problem... IE when I whacked the module, it would straighen out (or make worse) the problem. To make a long story short, the problem seems to be a weak (and now BROKEN) lead on one of the spectrol 149 100k pots. (Course on the 300) Crap. I *think* there's an electronics shop relatively locally that carries 'specialty' parts, so I'll check there at some point, but... does anyone have a 'spare' pot I could use/buy? I'll probably gut one from my as-of-yet unassembled 800 if it uses 100k 149s, will check later tonight. DAMN I feel special. Oh well, I had loads of fun before it got unstable and the lead broke. -Geoff
