Tranny Q
Tranny Q
2004-06-10 by Tentochi
I know some of this has been mentioned here before, but I forget all of the
details and I can't find it in the archives.
Can someone please explain the differences between the BC549 and BC550 and also
between the BC559 and BC560?
Second, what are the differences between the A, B and C types?  What if an A, B
or C is NOT given after the part number?
Are there any practical differences between these transistors when they come
from different manufacturers?  In particular, Vishay and Fairchild?
Thanks!
Shemp
Do you Yahoo!?
Friends.  Fun.  Try the all-new Yahoo! Messenger.
http://messenger.yahoo.com/
Re: Tranny Q
2004-06-10 by charlesosthelder
all of the
More complete info can be had on the web from the datasheets for each
of these devices.
BC550 and also
There is very little difference aside from the average gains and
noise from a given number of tested devices.  The difference between
the 549/550 and 559/560 is polarity- the former is NPN and the latter
is PNP.  Transistors have quite wide tolerances.  It is not uncommon
to find great variations in noise or current gain (hFe)when testing
even a small number of devices.  In most circuits, this won't make
any difference.  In fact, as long as the transistor has the correct
polarity, you can usually substitute freely with only minor resistor
value changes to make sure the device pulls enough current.  You may
get more or less noise, but those differences would occur within a
single transistor part number!
What if an A, B
See above.  These letter suffixs usually denote "improvement" in the
average specs of a specific number of tested devices.  In some cases
these specs can be radically different (BC108C's come to mind, with
average hFe of 500!)
they come
Not anymore!  You can bet that your transistor was made by little
girls in some Asian country while being physically and mentally
abused, regardless of the name on the label.  There shouldn't be any
variation in the average specs (see above) but it would be impossible
for the average user to tell, much less care.
> Thanks!
> Shemp
It's my job, sir and your'e welcome.  For a really good learning
experience, build a small, single transistor, common emitter
amplifier circuit on your protoboard.  Then drive it with a bit of
white noise or a square wave and watch the output on a 'scope.  Heck,
you could even listen to the difference through an amp and speaker.
Leave all the components the same but change transistors.  Even
within the same part numbers/suffixs/manufacturers, you'll be able to
discern the differences.
Chub
ps- remember the word "transistor" is a contraction of two words -
Transistional Resistor.  Dropping that bit of tid in conversation at
cocktail parties will guarantee that you'll never be invited back!
Perfect for avoiding dull events while you work on your music!
> Do you Yahoo!?
OT line mixer (please help!)
2004-06-10 by edibennardo
I apologize for the OT but any suggestion would be highly appreciated.
I had posted the same in the Oakley list days ago but got no reply.
I wanted to purchase a line mixer with very simple features but I
don't think there's anything available that matches my needs. What
I'm looking for should have about 20-24 balanced line inputs, no gain
no attenuators, only a panpot controller on each (mono!) channel and
a stereo output with master volume, that's all. I need it to connect
my two TX816 (8 balanced outputs each) and another two keyboards.
Item offered in the shops are mainly with stereo pair inputs and
balance control for the pair that has nothing to do with panpot on
each channel. Maybe somebody here in the list can suggest a simple
diy project that I could try to build, in the end even a more simple
design, many mono inputs and only one mono output (with attenuator)
would be fine. I'm sure many people in this list can give precious
tips, many thanks.
Enrico (Italy)
Re: OT line mixer (please help!)
2004-06-11 by charlesosthelder
Hey Enrico!
I started a discussion exactly like this, sometime last year.  Check
the archives.
I solved my mixer "problem" with two MOTM-830's and two ' 890's.  For
the synth monitor, I use a small Behringer.  For recording, the
signals come straight out of the MOTM mixers and into the recorder-
no compression, EQ, safety off, cocked and ready to rock!
Rane makes a line mixer that might work for you.  Mackie used to and
you might look at Peavey and Carvin.
Good luck!
Chub - sittin' in the mix
appreciated.
gain
simple
> tips, many thanks.
> Enrico (Italy)
