FT: Dark Star Chaos, JLH 822 V-shift (kits?) plus MOTM 850 + pedal
2004-05-20 by Justin Sane
For trade:
One assembled MOTM 850 pedal interface plus Yamaha CV pedal.
822 voltage shifter I got in a trade, has pcb, panel (needs to be
drilled), and a whole crapload of parts (which I believe is everything
you need to put it together)
MOTM format Darkstar Chaos, pcb, panel. I got this in the same trade,
the guy started it and never finished assembling it. It looks like it
just needs to be wired up, pcb is stuffed.
Also in the box are some
spools of wire, 2 brackets, and some solder.
Ideally I'm looking for out of the ordinary assembled modules (cgs,
cyndustries, etc). (If I was capable of building these, i would have.
(but i'd still trade the darkstar, i already have one)).
I can provide pictures etc if necessary.
thanks
Ray
Re: [motm] FT: Dark Star Chaos, JLH 822 V-shift (kits?) plus MOTM 850 + pedal
2004-05-21 by J. Larry Hendry
Remember, the 822 PCB is no longer available. Aftermarket is the only
source.
822 voltage shifter I got in a trade, has pcb, panel (needs to be drilled),
and a whole crapload of parts (which I believe is everything you need to put
it together)
2004-05-22 by MOTM Markk
... and I have two of them... (not fer sale!)
Sent: Friday, May 21, 2004 4:37 PM
Subject: Re: [motm] FT: Dark Star Chaos, JLH 822 V-shift (kits?) plus MOTM 850 + pedal
source.
it together)
