Blacet to MOTM Converter Panel
2004-04-21 by coyoteous
I'm looking for opinions on the "Blacet to MOTM Converter Panel":
http://www.blacet.com/motmconvFP.jpg
http://www.blacet.com/misc.html  (near bottom).
How does the finish compare to MOTM/Stooge type/quality?
Do the panel size and mounting hole placement follow MOTM standards?
Do the pilot holes line up with the MOTM grid?
I assume this is one in action with a Noise Ring:
http://www.retrosynth.com/slideshow/ahmw04/ahmw04_049.jpg
(seems a bit out-of-kilter).
Thanks, Barry
Re: [motm] Blacet to MOTM Converter Panel
2004-04-21 by J. Larry Hendry
The finish is different.  It appears to be a powdercoat to me as opposed to
wet paint.  Paul and Stooge Products both use Sherwin Williams Polane.  So,
the finish is slightly different.  However, it is quite nice.  Given that
the module will be completely different, I would say the difference in the
finish is acceptable.
The holes see to be in the right place. certainly within a few thousandths,
if not right on.  They fit just fine in yur MOTM rig.
They seem to be very close.
Yes, I got this one specifically because I wanted to be able to mount the
Noise Ring up in my MOTM system for AHMW 2004.  Your observation that is is
out-of-kilter is indeed correct.  However, that is not fault of the
conversion panel.  Clearly, John sells this as a "Blacet" to MOTM conversion
panel.  You cannot assume that also means ALL frac rack to MOTM conversion.
The two pots on the edge of the Wiard panel are too close to the edge and
conflict with the metal cutout.  I had to either enlarge the metal cutout,
or skew the holes off to one side to make it fit.  Since I was in a hurry,
It was easiest for me to just stretch by drilling the mounting holes to one
side. If it had been a permanent installation, I would have taken the time
to grind the hole out larger around the pots where the conflict with the
panel.
Larry H
Re: Blacet to MOTM Converter Panel
2004-04-22 by coyoteous
Thanks to Larry and those who responded privately.
Barry
--- In motm@yahoogroups.com, "J. Larry Hendry" <jlarryh@i...> wrote:
> From: coyoteous <antithesist@m...>
So,
is is
conversion.
> panel.
> Larry H
