Building Powerone PSU in cabinet?
2004-01-14 by Robert van der Kamp
I just finished my first cabinet (a wooden 19" case, 16 HE
high, 10 inch deep), and would like to install the PowerOne
PSU's from my 900 and 950 kits directly in the cabinet.
Any suggestions/tips? For example, is heat a problem when
mounting the PSU directly on the wood? Or should I use
spacers?
My plan is to mount a power strip in the cabinet, place both
PSUs in the cabinet, and connect both of them with the
power strip using standard power cables. I'll also power my
little MCV from that strip.
Then one cable is leaving the cabinet (the one from the
strip) and this will be connected with another strip which
has a switch, so that I can switch on/off the whole modular
in one go. A future second cabinet will end up in that same
switched power strip.
Good? Bad?
- Robert
Re: [motm] Building Powerone PSU in cabinet?
2004-01-14 by Paul Schreiber
Use spacers off the wood. They do not need to be very tall, only 2mm or so is
needed.
Do NOT connect 1 power strip into another powerstrip, where *both* have 'surge
protection' (ie MOVs). This is a VERY BAD IDEA (my long discussion is in the
archives). If you can't find a power strip without surge protectors, they you
have to find a way so that both are individually connected to the AC mains.
Paul S>
> tall, only 2mm or so is needed.
OK.
> where *both* have 'surge protection' (ie MOVs). This is a
> VERY BAD IDEA (my long discussion is in the archives). If
> they you have to find a way so that both are individually
Powerstrips with surge protection are rare here, so that
problem won't happen. ;) I hoped to find a strip with
surge protection to replace the fuse in the 900 and 950
front panel connector. Will that be okay, or is that even
*needed*?
- Robert
> *needed*?
Are you trying to give me a *heart attack* so early in the day?
NO NO NO!
The fuse had *absolutely nothing* to do with AC power surges (which are 95%
caused by lightning). The fuse is for a failed power supply (i.e. the Power One
itself failing) and causing the fuse to blow, which prevents your rack from
*catching on fire*.
> > that problem won't happen. ;) I hoped to find a strip
> > with surge protection to replace the fuse in the 900
> > and 950 front panel connector. Will that be okay, or is
> > that even *needed*?
> the day?
Well at least I saved you a couple of Dr. Peppers.
> NO NO NO!
> surges (which are 95% caused by lightning). The fuse is
> for a failed power supply (i.e. the Power One itself
> your rack from *catching on fire*.
I see! Okay, the fuse stays in. ;)
I should stick to programming, I know...
Thanks, and sorry for the shock.
- Rovert
2004-01-14 by Mike Estee
> *needed*?
Ack! Don't do this! Without a fuse if your power supply fails or a
module shorts your rack starts drawing as much current as the house
wiring can provide, which effectively turns your rack into a nice
little space heater!
As I understand it a surge protector handles over voltage. A fuse
handles over current draw.
--mikes
> fails or a module shorts your rack starts drawing as much
> current as the house wiring can provide, which
> effectively turns your rack into a nice little space
> heater!
> voltage. A fuse handles over current draw.
Thanks for the warning. I threatened the existance of this
whole community by attacking Paul's health with this
question. Good thing I'm smart enough to admit I'm
stupid. ;)
- Robert
>> heater!
> stupid. ;)
I wouldn't go that far, how about just uninformed? ^_^ I'm still
building a mental model about how this whole "electricity" thing works
too. It's very strange to a software engineer...
--mikes
2004-01-14 by Neil Bradley
> > stupid. ;)
My father taught me electronics at a very early age and the best analogy
at the time was this:
Voltage = How fast the water is flowing
Current = How much water is flowing
Resistance = Anything that restricts the flow
Personally I think that basic electricity fundamentals should be taught to
everyone. Not that they need to deal with signal integrity, but basic
mechanics of power is important in every day life. Most people don't
realize, for example, that water is a POOR conductor of electricity even
with impurities. One statement I've seen lately was a partner of mine shut
off a pinball machine that was plugged in to an extension cord because the
"extension cord was wet" instead of unplugging the extension cord. Simple,
basic knowledge of power could contribute to safety in everyone.
-->Neil
Neil Bradley "Your mistletoe is no match for my T.O.W. missile!"
Synthcom Systems, Inc. - Santabot - Futurama
ICQ #29402898
>>> stupid. ;)
> analogy
yeah, I've heard that one. it breaks down rapidly as soon as you start
to do anything complex though. i personally think that analogy is a
barrier to understanding single flow, and should be the first thing one
abandons when trying to learn this stuff "for real."
i'm finding there's no substitute for experimentation, and an
oscilloscope ;) my understanding of all this grew ten fold after I
could watch the circuits do their thing in a scope. (for fun stick a
scope in the output of a 48Khz virtual analog synth and compare a
square wave at 8khz to an 8khz square from the motm ;) ) i'm probably
learning all this stuff in a rather unorthodox manner as well. being a
software engineer I've started at the digital end of the spectrum, and
as a problem arises in the analog domain (signal integrity, etc) I
learn about how to fix the problem, what causes it, and of course, how
to diagnose it ;)
Hey more experienced people, other than the Art of Electronics, what
would you folks recommend for someone wanting to learn more about
analog electronics? I know you're lurking out there ^_^
--mikes
Re: Building Powerone PSU in cabinet?
2004-01-14 by Mike Marsh
For learning basic electronics, Radio Shack has (had?) a series of
mini-books that were pretty cool. Also, for stuff targeted at music
electronics, there nothing like Electronotes, the early ones.
Finally, Projects for Guitarists is really great and you can get the
PCBs (and the book) from PAIA.
Mike
> >>> stupid. ;)
thing works
> > analogy
start
a
thing one
a
probably
being a
and
how
> to diagnose it ;)
what
> --mikes
BTW, that was posted by someone who doesn't know shite about
electronics... :)
music
> Mike
> > >>> stupid. ;)
still
> thing works
best
> > > analogy
> start
is
> a
> thing one
I
stick
> a
a
> probably
> being a
spectrum,
> and
I
course,
> how
> > to diagnose it ;)
> what
about
> > --mikes
On Thursday 15 January 2004 00:56, J. Larry Hendry wrote:
> Depends on the voltage and how much conduction bothers
> you. At several hundred volts, the conduction is good
> enough to kill you.
Ah, I feel better already. :)
One more reason to study electronics. I want to know what's
going on there behind those pretty panels. I'd like to be
able to actually understand Paul's explanation of the
modules I built. Wonder how long that will take. :(
- Robert
2004-01-14 by J. Larry Hendry
> From: Neil Bradley <nb@...>
I'd change that one to = What is the water pressure
> Most people don't realize, for example, that water is a POOR conductor of
electricity even with impurities.
Depends on the voltage and how much conduction bothers you. At several
hundred volts, the conduction is good enough to kill you.
LH
Re: [motm] Re: Building Powerone PSU in cabinet?
2004-01-15 by Richard Brewster
Ditto the Electronotes. EN contains all levels of explanation of
electronics, from basic Ohm's Law to calculus. And it's in the context
of modular synthesizers and the physics and perception of sound.
Essential reference material for serious synth DIY folks. And the
entire collection fits neatly into just nine three-inch binders :). I
can sit and browse through my EN collection for hours.
-Richard Brewster
>Mike
2004-01-15 by Robert van der Kamp
> explanation of electronics, from basic Ohm's Law to
> calculus. And it's in the context of modular
> And the entire collection fits neatly into just nine
> three-inch binders :). I can sit and browse through my
Are these still for sale, the early ones?
Electronotes
2004-01-15 by mbedtom
I too highly recommend Electronotes. I have only selected issues but
what I have is impressive. (I actually got them when they were first
issued. That makes me a real old guy!) I've never posed the
question, but why on earth hasn't Electronotes been turned into a PDF
document and distributed on a $0.22 CD instead of killing a small
tree for the whole lot? I would love to have the entire set but I
would have to scan them into PDFs and then recycle the paper. Since
that is such an obvious question I must have missed something along
the way... feel free to flame me for not knowing about the obvious
<insert whatever it is that I don't know that is obvious to everyone
but me>
Cheers!
Tom Farrand
2004-01-15 by Scott Juskiw
You can still get Electronotes:
http://electronotes.netfirms.com/
2004-01-15 by Mike Estee
Yes. I recently bought the whole set ($300) from there website. It's
kinda of a pain as it comes unbound though. I keep meaning to find a
binder and have them put into book form. The box is really heavy too,
so shipping is slow and expensive.
--mikes
