[motm] My Tolex cabine
2004-01-07 by elhardt@att.net
John Speth writes: >>I know there are a lot of Tolex covered cabinet naysayers out there but here's my example that shows it can look good. Take a look at the files section of the MOTM group under the Tolex Cabinet folder. With MOTM, you get that "black beauty" look.<< Still using Tolex? I thought after I discovered the vinyl convering at Penn Fabrication people would be using that. It's about three to four times less expensive than Tolex. I still have some pictures of my "black beauties" online. That's also black inset handles and corners. Once I delete them, they're gone for good. http://home.att.net/~elhardt2/cases_construction.jpg http://home.att.net/~elhardt2/motm_case.jpg http://home.att.net/~elhardt2/cavalry_antiqued.jpg -Elhardt
