Re: Plexiglas Panels (more)
2004-01-02 by paulhaneberg
More thoughts on Plex Panels: If you want a clear panel I would
recommend Plex rather than polycarbonate or Lexan. I believe Plex
is more resistant to scratching. If you want a tough durable
plastic use ABS. As someone else mentioned ABS is the plastic used
in car interiors. It drills and cuts far easier than Plex, but I
doubt you can get it in transparent. If you are going to glue
anything to it a special glue is required as it is too slippery for
most plastic glues. Even epoxy will not adhere to it. For a really
unique panel drill your Plex, put clear labels with white letters on
the back side (so you can read them through the Plex), then spray
the backside black over the letters. Be sure the paint you use
doesn't dissolve the lettering. You could also try printing a full
size panel on your computer printer and putting that on the backside
of the Plex. If you try this probably inkjet is best as you need a
really dark black. As you can probably tell I've been experimenting
with making panels for a long time.
Re: [motm] Re: Plexiglas Panels (more)
2004-01-03 by Scott E.
Acrylic is also not so scratch resistant, but more so then Lexan as you
suggest. There are cast acrylics that are manufactured specifically to
be resistant to scratching, but are more expensive than the normal cast
material.
Most glues simply will not work well. There are adhesives designed for
acrylic, though, and there are different consistencies of the adhesives
available. Check out Weld-on adhesives at the link below to view the
ones right for cast acrylic materials (Weld-on #3, #4 or #16).
The only way to truly join acrylic pieces together is with acetone. This
bond is similar to a weld as the acetone melts the acrylic. Needless to
say, the edges must be very smooth for this process to work properly, as
acetone is quite thin. Sanding might be good enough if you are careful.
In a production environment, we would use a hydrogen/oxygen torch to
smooth the edge. One also must be very careful to not get acetone on any
portion of the material that is not to be bonded, as the material will
"craze" over time.
Scott
Link for Weld-on:
http://www.ipscorp.com/ind_html/acrylics.html
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/motm/
> motm-unsubscribe@yahoogroups.com
> Your use of Yahoo! Groups is subject to:
> http://docs.yahoo.com/info/terms/
