slight OT-synth limiting
2003-11-25 by osthelder
Hey all!
I'm looking for MOTMer feedback about the FMR Really Nice
Compressor.  With the price of two for $380, including the Funk Logic
dual rack mount kit, it would seem just the ticket given the present
layout of my synth and monitoring gear.  Anything would be better
than this cheap dBX 166...
So, please tell me what you think of the RNC.  Does it limit without
noise- pops, crackles or other DC artifacts?  Does it handle the
synth signal (that 9 volt wall wart is less than reassuring...)?  All
I want to do is limit the output to protect my speakers and prevent
clipping at the mixer input. I don't need to squash the dynamic range
to fatten this sound!
There's a lot of good press on this unit, but few reviewers are using
large analog modulars!  Please let me know your experiences.
Chub- self-limiting (hard knee...)
Re: [motm] slight OT-synth limiting
2003-11-25 by Sikorsky
i really like the TC Electronics Triple C (make sure you get the stereo
version)
not only is it a very useful (multiband) compressor, but you can use it as
your main AD convertor
they're dead cheap here i the UK...
cheers
paul b
sheffield
uk
2003-11-25 by Paul Schreiber
I had one, but the tc electronics Triple-C blows the doors off it.
Re: slight OT-synth limiting
2003-11-25 by Mike Marsh
Hey Chub -
For what it's worth, I don't compress or limit the signal from the
modular to my deck.  I use the trim on the inputs to match levels.
If an occassional signal is still to hot, I attenuate in the synth.
I tried using compressors, both outboard and digital and it just
kills the dynamics.  On some tracks, very rarely, I'll add a little
compression to get the track to 'sit' in the mix better.   I rarely
use EQ, either.  I like to get the right dynamics and timbre out of
the synth and record it naked. I do use reverb and delay, and some
other weird Kyma stuff more, though.  When i mix down, I sometimes
use a limiter to boost overall track gain, but less and less lately.
I have a nice Aphex that I use on vocals.  It's mono, but pro and
sounds pretty nice.  Another inexpensive compressor that I like with
guitar and with the MOTM is the ART TubeCompressor.  Inexpensive but
pretty fat sounding.  The compressor in the Roland S-50 sucks, as
does any compressor from Alesis that I've heard.  Opinions, opinions.
Mike
--- In motm@yahoogroups.com, "osthelder" <osthelder@n...> wrote:
> Hey all!
Logic
present
without
All
range
using
Typically, I don't compress anything.  With the synth I wanted some
limiting going on to prevent blown tweeters while experimenting.
The '266 is set up to limit but strong peaks cause an annoying
popping sound which I attribute to the VCA of the dBX.  Attenuating
at the output mixer(s) of the synth take care of this and leaves the
limiter effectively out of the picture.
I guess that it just bothers me to have ANY artifacts of the limiter
in the signal chain.  Maybe I should just fuse my tweeters and pull
the '266 from the rack.  They way I'm using it now seems a bit of a
waste.  Thanks for the "correct" answer, Mike!
Chub- no limits
--- In motm@yahoogroups.com, "Mike Marsh" <mmarsh@w...> wrote:
> Hey Chub -
with
but
opinions.
> Mike
> > Hey all!
> Logic
> present
> without
> All
prevent
> range
> using
2003-11-26 by Eric Frampton
I've not used it as a limiter, but as a compressor there is no other
serious option under $500 list. Maybe even under $1k. It's pretty
amazing. Don't let the wall-wart stand in your way.
While I haven't heard of it being used as a limiter in a monitoring
situation, it is certainly transparent enough to handle it. What I'm
not sure of is whether it would be -fast- enough to grab a transient
before it fried a tweet, although the detector circuit in there is
pretty stinkin' fast.
There's lots in the Usenet archives at Google in rec.audio.pro. Do a
search for RNC and you'll come up with volumes.
e
Re: FMR RNC
2003-11-26 by Jim Black
RNC is a really clean compressor. It sounds really
good if used properly and with the right materiel.
I've found... program materiel good, kick drum good
(and drums in general), synth (esp. synth bass) not so
good. I usually only compress (to tighten) synth bass
and percussive synth sounds.
I bought a Distressor for synth and it sounds
fantastic. I also had a Meek for a while. It sounded
good on synth bass, but not so good for program or
drums. YMMV.
check the archives on rec.audio.pro.
Do you Yahoo!?
Protect your identity with Yahoo! Mail AddressGuard
http://antispam.yahoo.com/whatsnewfree
2003-11-26 by Adam Schabtach
I can't help but think that most of the replies to the original query have
missed the point. The original query was (in part):
> All
Most of the replies have focused on the relative merits of compressors and
compression, which is a related but different topic. It seems to me that the
original query hasn't really been addressed, and is relevant to this list.
Or maybe I just think it's relevant because it's something I've wondered
about myself. :-)
So maybe I'll try putting a similar query in my own words: is it sensible to
use a peak limiter between the output of a modular synth and the input of a
mixer or A/D converter or whatever you happen to be using for monitoring and
recording, not for controlling the dynamics of the signal but for protecting
your input stages/pre-amps/power amps/speakers/ears (most important) from
the 10V p-p signals present in a MOTM? If so, what is a good unit for this
task?
Under normal circumstances, of course, the output of a synth is nothing to
worry about--the output signals are much smaller than the 10V p-p modulation
signals. But accidents happen (happy accidents being one of the reasons to
own a modular in the first place) and it seems to me that it can't be a good
thing to plug the unattenuated pulse output of a 320 LFO directly into a
pair of powered monitors, for example. It'll scare the pants off you and
anyone else around, for one thing.
I've adopted the practice of always using an 830 mixer as the output point
of my MOTM; that is, I connect the output (OUT 2) of the 830 to my mixing
desk, A/D converter, whatever. I start with all of its level knobs rotated
fully CCW and turn them up slowly after patching new signals into the mix.
This is only a partial solution, though.
(As an aside, I have an RNC compressor and am very fond of it. I haven't
tried using it as a peak limiter, but it's lovely for other tasks.)
--Adam
2003-11-26 by Mike Marsh
This is what I was trying to say with my original reply: I don't
need to limit the output of the MOTM even when generating nasty
timbres.  I use the trims on the inputs of my mixer, because
compression/limiting affects the dynamics of the track too much
(most of the time).
Mike
query have
> > All
prevent
range
compressors and
me that the
this list.
wondered
> about myself. :-)
sensible to
input of a
monitoring and
protecting
important) from
for this
> task?
nothing to
modulation
reasons to
be a good
into a
you and
output point
mixing
rotated
the mix.
haven't
> --Adam
