Re: Testing Your Studio
2003-10-27 by paulhaneberg
I used a similar method for determining the proper frequency for bass traps in my control room. I recorded a series of sine waves into ProTools at different frequencies then truncated them at the zero crossing points. I played them through a set of monitors (a pair of JBLs that I had the manufacturers frequency response plot for.) I recorded the tone bursts back into ProTools using a flat mic and preamp. The microphone was placed at the console center listening position. I tried several different locations for the monitors to eliminate standing waves but mostly used the near field position. I then determined the room response by adjusting the amplitude of the re-recorded tone bursts for the frequency response of the monitors. I also looked at the amount of time the room "rang" at the different frequencies although some of this was probably due to the speaker cones ringing. I did determine an optimum frequency for bass traps and constructed them to attenuate that frequency. That and the overall shape of the room as well as the combination of absorbant and reflective materials yielded a room within 3 db of flat and with great imaging. The downside was that in an attempt to "excite" the room into resonance I blew the woofers in both monitors. So be careful!!! I was not in the room when I tested it. I value my hearing! Another interesting technique is to place a white syrofoam ball where your head will be (in the center monitoring position) cover all reflective surfaces with aluminum (aluminium for you Brits) foil shiny side up. Take a laser pointer and hold it where your monitors will be and see whether you can prevent any reflections from hitting the styrofoam by adjusting the angle of your console and other equipment. You'd be amazed at how much the elimination of first order reflections will improve the sound of a room.
