cable update and 3.5 mm info
2003-10-22 by J. Larry Hendry
Today, the sample for 3.5 mm cables arrived.  I was somewhat surprised.  I
was expecting a smaller diameter cable coupled with the smallish hard to
grab 3.5 mm cables I have seen in the past.  Instead, I found the cable for
3.5 mm phone plugs is identical to the cable already used for "Wise Guy
Synth" branded cables.  And, the 3.5 mm end has approximately the same
barrel diameter as the 1/4" phone plug.  Wow!  This is one good feeling
connector.  I have updated my cable pages with the information I have.
http://www.wiseguysynth.com/larry/cable/cable.htm
Now, some of you may say "Wow, I like that" and order some.  Some of you who
have already send 3.5 mm cable orders may NOT like it.  If you do not, you
may cancel and or part of your cable order.  Heat shrink is also available
on the outside of the barrel.
I am still sorting through cable orders.  Never fear.  I will start sending
out some invoices yet tonight and hope to have them all out in a few days.
If you somehow missed out on the original notice that we were going out for
another custom cable order, it is not too late.
Larry Hendry
