Mildly interesting MOTM-480 plots
2003-10-14 by Paul Schreiber
Here are some different plots of the MOTM-480 VCF, which is a clone of the Yamaha CS-80 filter
section. The filter structure is 2 state-variable filters in series, but with independent
resonance and cutoff frequency panel controls. The patched control voltages (cutoff and
resonance) add/subtract an *offset* from the panel settings. You can get all types of filter
curves, as the graphs show.
There are 2 documents: the MS Word version is easier to read and 1/10th the size of the PDF (PDF
does NOT like BMP files!)
MS Word (150K): www.synthtech.com/files/m480.doc
PDF (1.3MB): www.synthtech.com/files/m480.pdf
Sound examples in a few weeks as the tweaking begins :)
Plots generated on an Audio Precision Series 2 DSP analyzer (www.audioprecision.com)
