Sine Waves
Sine Waves
2003-09-22 by foraxx
I've heard that it is difficult for a VCO to create a sine waveform
(or really a good quality sine wave).  Is this true and why is it
so?  Its obvious to me that it would be harder to generate a sine
wave in comparison to a square wave, but what is specifically
challenging theoretically and in practice?
Some people complain about the purity of sine waves generated from
VCOs.. does this matter to you?  Do you find sine waves useful in
subtractive synthesis or could you do without this waveform?
RE: [motm] Sine Waves
2003-09-22 by Brousseau, Paul E (Paul)
Can't say much about how hard they are to produce, but I would imagine that it's not easy to get that "perfect" curve shape in the analog domain.  Digitally it's easier, since you can just use a DSP to perform a mathematic function.
Are sine waves useful?  You bet.  Great for re-enforcing bass.  In terms of purity, well, I haven't compared any, so I couldn't tell you.
--PBr
Sent: Monday, September 22, 2003 3:46 PM
To: motm@yahoogroups.com
Subject: [motm] Sine Waves
Re: Sine Waves
2003-09-22 by Mike Marsh
Yes, even the mighty 300 doesn't produce a pristine sine wave.  There
are some harmonics produced, even in a finely scope-tuned 300.  In
practice, for adding beef in the sub-bass region for e.g., this isn't
much of a problem.  But if you really want pure sine waves, any of
the MOTM filters will oscillate and the 440 in particular tracks well
over an octave or so (perhaps more).  For nice bell tones and ring
mods, I use oscillating filter output.
Mike
Re: Sine Waves
2003-09-23 by mate_stubb
The common method for generating a sine output from a VCO involves
taking the native waveform that the vco generates (usually a
sawtooth), then deriving a triangle (often with a small notch at the
peak), then using the derived triangle to drive a CA3080 into the
nonlinear region to approximate a sine wave. The key word here
is "approximate". It is not that pure. An oscillating VCF, however,
can generate a very pure sine wave. When I do FM and cross linked
chaos patches, I generally get better results when both modulator and
modulatee are oscillating filters.
Moe
Re: Sine Waves
2003-09-23 by Mike Marsh
What he said :)
and
> Moe
waveform
