Re: thoughts from a newbie
1999-10-22 by Paul R Bower
hello all (from sheffield, england) got the first parts of my system on monday but a rogue earth loop and attempting to sync a multitrack to cubase vst has caused me a week of abject terror... but i digress i've not had chance to build my system yet (that would be 8:30pm tonight), but having a good poke around the kits, i've come up with the following suggestions / mods that i'll be making: in the power supply module, i'm going to put a folded aluminium shield around the transformer assembly, just for a little more protection when poking around the back of the system - the 240v we have is a little more serious etc etc racking wise, i encountered a little problem with the 19A rails which are designed to fit with what we call M5 bolts. UK users will know that quite a lot of UK racking / caged nuts uses M6 bolts, which don't fit - a solution i found was that a set of humfrees (M6 bolts with an insulated sleeve) can be used. strip off the insulation, and you have an M5 bolt with an M6 thread. (they're \ufffd7 for a pack of 4 from studiospares 0171 482 1692) I just ordered an \ufffd55 5u rack case from a german company called Thomann, i'll let you know how it goes, but in the long run i plan to use some spare neve console chassis parts - the parts i have (for an '82 51 series) are based on 19" compatable bays - the plan is a series of 11u wide, 10u high shallow cabinets, power on the back, edac / elco connected audio loom, with front panel patch points, and a couple of 9v / 12v supply points available for any pedals i want to use (amperes permitting). a question - does anyone over label their patch fields with coloured ink to easily code CVs from audio. i only caught the end of the coloured washer saga, but thought red & green markers over the white screenprint would work... (on my korg MS bits i use red cables for cv, green for gates) finally, hands up all those who'd like to see a series of drum modules some time in the future..? cheers paul b ps - my headspace can be explained at www.pasc.syol.com it's not been updated since march - but check out the PG52B modular pulse generator ;-)
