Fender amp, Part #2
1999-10-23 by Paul Schreiber
<<just taking a little break for MOTM, folks! Not to worry>> OK, here is the scoop. The head amp is a "chop job". It *is* a blackface (chassis #A09196) Super Reverb Amp. But somebody put the "guts" in a custom Fender-ish case. Has Tung-Sol 6L6 output tubes, which means about 1967 (!?!). I'll post to rec.whatever and try to pin it down. The original Fenders had a "Tube Replacement Chart" stuck to the inside, that doubled as a serial tag. There is an encoded date on this tag, but mine's missing ! :( The cabinet has 2 Sunn "Guitar Transducers" speakers, 15" each. There are 2 small tube ports and a wooden "shelf baffle" inside. The back has a 1/4" plug and the 2 speakers are just in parallel. The damn thing had 36 screws in the rear cover plate. These is no name inside or out. This may be non-Fender as well. Anyway, 2 tubes are dead (no filiments), all other are glowing. Input tubes are all 12AX7/7025 types with a 12AT7. Paul S.
