Any reasonable CV keyboards out there?
2003-06-15 by ivancu2
I can't seem to find much in the way of small CV keyboards that
are affordable.
I've been thinking of building a PAIA midi2cv8 into my Novation
MM-10X keyboard and using that as a dedicated modulary
synthesizer controller.
Any thoughts out there for something small and affordable?
Monophonic is fine with me (for now).
Thanks!
Ivan
Re: [motm] Any reasonable CV keyboards out there?
2003-06-15 by jwbarlow@aol.com
In a message dated 6/15/2003 9:05:31 AM Pacific Daylight Time, ivancu@...
writes:
> are affordable.
I haven't seen a reply to this so I'll just throw out my two cents.
The only CV keyboards I've heard about recently are the synthesizers.com (is
that the name of the company?) for like $500. And I'm sure you remember the
Roland CV keyboards that showed up at some shop in NYC about two years ago (and
disappeared in the blink of an eye).
You also might want to check this out:
<A HREF="http://sales.goldmine-elec.com/prodinfo.asp?prodid=8280">http://sales.goldmine-elec.com/prodinfo.asp?prodid=8280</A>
This was posted on synth diy about a week ago. I've been thinking of getting
one (as if I need another project). There would still be some work to make a
voltage source for the keys and you'd have to install a resistor per key (and
stuff like this never turns out to be easy). You could easily make this
keyboard far more accurate then the Moog and ARP (and all the other CV keyboards) in
their day since it would be easier to match the resistors, or you could ($$$)
use 0.1% resistors. You'd probably also want to add some sort of bender/mod
wheel -- I have no idea where you'd get something like this except from a
thriftshop Casio or some such thing.
I have a PAiA midi2cv8 and it works OK. I believe Tony A. posted a bunch of
mods to make it a bit better. I figure I can use it for non-critical voltage
sources or gates. I also have a couple of unfinished Oakley Midi 2 CV PCBs which
looked like a good idea when I got them, though some of the parts are rather
expensive (as one would expect for a high quality convertor).
Of course, right after I got the Oakley Midi to CV PCBs, Paul announced the
MOTM Midi CV convertor. So obviously that's my final (and best) suggestion. I'd
use a basic MIDI keyboard patched into the MOTM MIDI convertor -- save
yourself the hassle. I know this was originally supposed to ship last month, but I
imagine it's getting pretty close by now.
Good luck!
JB
RE: [motm] Any reasonable CV keyboards out there?
2003-06-15 by Les Mizzell
:: The only CV keyboards I've heard about recently are the
:: synthesizers.com (is that the name of the company?) for
:: like $500.
Keep in mind that the Synth.com keyboard is not a *true* CV keyboard. It is
a MIDI keyboard with built-in MIDI-CV conversion.  While it's very good for
the value (I have one...) there are limitations.
1. No left-hand performance controls of any kind.
2. Limited range - even running MIDI into it, you can't pitch bend ABOVE the
top note on the keyboard, or pitch-bend BEFORE the bottom note on the
keyboard.
Other that this, it's a great unit. However, if I had done a little more
research myself, I would have ended up with a small MIDI controller and a
separate MIDI/CV box...
Les
In a message dated 6/15/2003 2:30:51 PM Pacific Daylight Time, lesmizz@... writes:
keyboard.
That would make the choice even more obvious.
I also should note that I recall the behavior you describe in #2 on both my PAiA midi2cv8 and (I think) on the Fatman. I wonder if the MOTM can deal with this problem, as well as the zippering of the pitch bend?
Another (obvious) choice for a CV keyboard would be to get yourself an OB-1 or an SCI Pro One -- and get a free minisynth thrown in along with the keyboard.
JB
Re: Any reasonable CV keyboards out there? Other options.
2003-06-15 by elle_webb
> :: like $500.
Doepfer announced a CV keyboard that looked interesting a while back -
 but I don't know if it is shipping yet. It had CV output for every
key, in addition to outputs for the entire keyboard.
Analogue Systems makes a keyboard they call the French Connection
that is inspired by the Ondes Martenot. This is a really unique
controller - SOS magazine covered it about a year ago. Under the keys
there is a special pitch control wire that allows continuous slides.
They also have a combination midi/cv keyboard called the Demon. These
are both high-dollar options.
I'm using a Sequential Circuits Pro-One. This has gate & pitch CV
outputs, so it hooks right in. They're available for $400-500, so
they are a viable option, with the bonus of an awesome monosynth. No
touch sensitivity & crummy keyboard, though.
One off-the wall alternative is a Novation BassStation Rack Module.
This is a modern clone of the Roland TB303 BassLine synth. It does a
great job of getting techno sounds. The thing that sold me on it is
that it has CV & gate outputs. This lets you control the BassStation
on one MIDI channel, and use another MIDI channel to control the CV &
gate outputs. These show up used on Ebay fairly frequently. I paid
about $200, which is great a combination of an analog synth module
plus a basic MIDI-CV converter.
2003-06-15 by tontaub
Wow, lucky they are not utilizing Switchcraft 112A  ;-)))
Re: [motm] Re: Any reasonable CV keyboards out there? Other options.
In a message dated 6/15/2003 4:20:39 PM Pacific Daylight Time, egroups@... writes:
And lucky that it only has 25 keys. An interesting device (since it has "pressure" sensitive touch plates) but not much of a chromatic keyboard.
JB
2003-06-16 by Scott Juskiw
I sometimes try to use my Pro-One to control my MOTM. But as
mentioned above, the keyboard is quite crummy, and I usually give up
after a few minutes. The key mechanism needs constant maintenance to
repair dead keys.
2003-06-16 by Mark
On 6/15/03, Les Mizzell put forth:
>:: like $500.
I use a Prophecy, which has an excellent left hand section, with a
Pro 4.  You can wire up an adapter to convert the 6-pn DIN in the
back, or buy the Korg pedal built for it, to switch portamento,
sustain, etc.
I'm not a big fan of MIDI keyboards that aren't synths, there a ton
of them on the market -- from cheap little gizmos like the Oxygen 8
to 88-key full-weighted keyboards.  Some of them have USB in addition
to MIDI.
What I would love to see is a USB or Firewire CV-converter that
avoids the limitations of MIDI.
2003-06-16 by elle_webb
back -
> >  It had CV output for every key.
Yeah!
Can you imagine all the weird stuff you could do with that keyboard?
It and the Analogue Systems controllers seem to be targeted for
people trying to stay completely in CV's. You pay more to
stay in CV's...but when you're spending thousands on a CV system, a
CV controller is worth considering.
I like using a CV keyboard - it gives me CV outs and CV ins,
which gives you a lot of room to explore. For lead-type lines & for
experimenting, CV controllers offer a lot of benefits.
If you're not into that, a MIDI-CV converter with a Casio gives you
more bang for the buck!
2003-06-16 by Robert van der Kamp
> as mentioned above, the keyboard is quite crummy, and I
> usually give up after a few minutes. The key mechanism
> needs constant maintenance to repair dead keys.
Why not use a MIDI keyboard with a MIDI->CV converter?
Thaty's what I had planned, anyway. Will a vintage/original
CV keyboard do a better job?
- Robert
Re: OT-cleaning keyboards; was Any reasonable CV keyboards...
>up after a few minutes. The key mechanism needs constant maintenance
I had a similar problem. Mine was getting keys that wouldn't trigger,
or that would double-trigger.
The problem was corrosion & deposits on the trigger wires. I was able
to fix the problem using a contact cleaner pen (a few bucks at Radio
Shack). Carefully rubbing the tip against the top and bottom of the
trigger wires took the goo off.
There are a couple of other features on the Pro-one that I find
handy in a modular contect. The glide is applied to the CV out, which
handles my needs. The 40-step sequencer and the arpeggiator work fine
for electronica synth patterns. You can control pitch and filter
cutoff with external CV's, so the MOTM can assimilate it. Finally,
the Audio In can be used as a envelope detector/gate generator.
Sequential threw in a lot of quirky features that would be expensive
to duplicate new.
The keyboard IS still crummy, though! It's too bad that there's not
much of a market for interesting new CV controllers!
For a lot of stuff, even a inexpensive MIDI keyboard with a MIDI->CV
converter will do a great job.
In some situations, though, you may find benefits to staying in the
CV world. I like CV for monophonic lines. CV pitch bends and
glissando, for example, sound better to my ears. This is subjective!
A vintage keyboard may have other features, such as an arpeggiator, a
sequencer, or other controllers that you may find useful, depending
on the type of music that you do. Some of the better old keyboards can
be obsorbed into your modular, because they have both cv ins and
outs,
and they provide a lot of sound generating bang for the buck. Some
tasks are quicker with CV, too, because you just start patching
jacks.
So no, a vintage keyboard isn't a better controller, but they can be
better for different things.
I will probably do that once I get a MOTM-650 in my grubby hands. I
just wanted to point out that a Pro-One is a nice synth, just not a
great CV controller.
2003-06-16 by Richard Brewster
I don't have a keyboard or MIDI equipment.  I am not a keyboard player, but
I would like to have more manual controls over the synth.  The Doepfer
proposed keyboard is not shipping yet, but does look very interesting.
http://www.doepfer.de/a100tkb.htm
-Richard
2003-06-17 by jwbarlow@aol.com
In a message dated 6/16/2003 1:27:19 PM Pacific Daylight Time, scott@... writes:
I
That's why I mentioned it. I borrowed one once (a long time ago) and was really impressed considering what it is.
One of the things that's wrong with the more "vintage" keyboards is that they used a three buss system (one for gate, one for trigger, and one for the CV). These take a certain (minor adjustment in) technique to play since the "J" wire (is that what its called?) will touch the different busses at slightly different times -- or only touch one or two busses if the key isn't pressed all the way down. Also, there can be problems if the resistors weren't matched closely enough or if they have drifted -- I believe I have both problems with my ARP. (Vintage keyboard experts -- please correct me if I'm wrong here!)
I think that the Pro One probably uses a single buss and derives the gate and CV (probably no trigger) from that. And the sequencer is nifty too!
JB
2003-06-17 by Sikorsky
hello all,
they
CV).
etc...
so might this explain the difference in feel to a Roland 181 (gate &
trigger) and a Roland 184 (gate only)..?
i'm used to my 181 but my 184 mis-fires sometimes which feels like it's me
causing it (i am not a keyboard player...)
cheers
paul b
sheffield
uk
2003-06-18 by sasami@hotkey.net.au
>hello all,
>they
>CV).
>etc...
The 181 only uses 2 busses internally.
Ken
_______________________________________________________________________
Ken Stone   sasami@...
Modular Synth PCBs for sale <http://www.blaze.net.au/~sasami/synth/>
Australian Miniature Horses & Ponies <http://www.blaze.net.au/~sasami/>
2003-06-19 by coyoteous
Has anybody tried this one? It looks like it might be a nice match with a small
midi controller for monophony.
http://www.philrees.co.uk/products/miditocv.htm
Barry
> - Robert
