Got Fender amp, but......
1999-10-22 by Paul Schreiber
For the geetar folks out there:
Turns out what I received was a Fender Super Reverb Amp head
and the 4x12 seperate speaker cabinet. Does have the footswitches,
and also 2 of the 50's "Elvis" style metal mics DeKane Model 7A65.
So, what's the poop on this rig? He's also going to send me a Univox
drum machine circa 1972. (He bought all of this stuff new in '72).
Re: Got Fender amp, but......
1999-10-23 by J. Larry Hendry
Hmmm.  The Super Reverb I remember was all in one, not a head with separate
cabinet.  And, it had 4 10" speakers instead of 12".  I have never seen the
separate Super Reverb head.  The Super Reverb I remember really rocked.
The cabinet that came with the Dual Showman you thought you were getting
actually had two 15" speakers.  That was the only dual 15 cabinet I ever
saw made especially for guitar.
Larry (non-geetar folk that knew a few of them types over the years) Hendry
1999-10-23 by JWBarlow@xxx.xxx
In a message dated 10/22/99 6:31:38 PM, jlarryh@... writes:
>the
Yes, yes and YES! That "old" (not by Fender standards) Super is really great,
though you already knew that. I know nothing about the separate head Super,
or a 4 X 12 cabinet for that matter -- it seems a bit early for Fender to
have wanted to compete with half stacks. I don't have any of those "Amps of
the Stars!!!!" books, but I do have a big technical tube amp book called:
"The Tube Amp Book 4.1th Edition" by Aspen Pittman. It shows several
schematics for Super and Super Reverb amps. The tube list for the Super
Reverb is 4 - 7025, 2 - 12AT7, 1 6L6 duet, and possibly a 5U4. Does that look
familiar? I'm assuming it's a silver face too.
The Supers I'm familiar with were 40 watts (I think) at 2 ohms with the 4 10s
in parallel, so the 4 12 cabinet isn't a stretch (and I like 12s too,
especially Celestions or Jensen Special Designs). I believe Fender used
Jensens in the old days, JBLs in the 60s and in their high end models, and a
lot of "Fender" speakers in the 60s and up. And of course the typical heads
are Bassman and Bandmaster, but you knew that too.
I seem to remember that Dick Dale may have had a lot to do with the
development of the Dual Showman, like Townshend and the Marshall, so the 15
makes more sense in that respect -- my first real amp was an Acoustic 100
watt with a 15" Altec, it was the wrong amp for me.
I hope someone else can help you more than I have -- of course you can always
sell it to Barlow for scrap!
JB
> From: JWBarlow@...
> I don't have any of those "Amps of  the Stars!!!!" books,
> It shows several schematics for Super and Super Reverb
> amps. The tube list for the Super Reverb is 4 - 7025,
Hey, anything in that book about the Dual Showman?  While Paul was awaiting
his shipment, I actually purchased a Dual Showman (head only).  Although
this one is in fine working order, a schematic would be nice to have.
However, back when I went to 'lectronics school, we learned to fix tube
amps without schematics.  The Dual Showman uses the same 6L6 push-pull
arrangement as the super reverb and bandmaster, except it has two pair in
parallel.  Officially, Fender rated it for 85 watts I think.
> ohms with the 4 10s in parallel.
Wow!  I didn't remember that the total speaker cabinet impedance was that
low.  I guess I always assumed that the 4 speaker cabinets were series /
parallel so that the cabinet impedance was the same as one of the speakers.
 Of course, I was only 17 and slightly influenced by recreational drugs
when we were using these things in high school.  However, the wattage you
remember should be about right. 2 6L6s should yield about 35 to 45 watts. I
think about 22 or 23 watts each was about all the heat the plate could
handle.
Larry (feeling old talking about tubes) Hendry
In a message dated 10/22/99 9:23:34 PM, synth1@... writes:
>The head amp is a "chop job". It *is* a blackface (chassis #A09196) Super
>Reverb Amp.
>But somebody put the "guts" in a custom Fender-ish case. Has Tung-Sol 6L6
>output
>tubes, which means about 1967 (!?!). I'll post to rec.whatever and try
>to
>pin it down.
I kind of wondered about this since a few years ago a guy at work was tell me
about a Twin Reverb he had -- I think he mentioned jamming or auditioning for
some metal band or something and using his Yamaha solid state amp (yuck!).
When I asked him about his Twin he said he needed more power (?) and didn't
like the sound (??) and how when you turned up the Intensity to get more
volume (???) it never got that loud, to which I replied "NO!" and he said
"but you know how you..." "NO!" We went on for a while and I persuaded him to
let me see it. It was a total mess, tolex ripped off one of the corners. That
corner joint had completely failed. Some absurd master volume mod using the
intensity knob (see lumbo reference below). A whole bunch of other stuff. All
I could think of was cutting the cabinet down to make a separate head so I
could use my 25 year old 4 X 12 SMF (same as Sound City) cabinet -- three
guesses what SMF stands for. He didn't want to let the Twin go, and when he
got it back he couldn't believe it was the same amp, he had no idea how much
power it was supposed to have.
As far as the black face goes, in the section of the book about Fender it
says: "many of the black faced amps, even the few produced by the early CBS
company are identical in specifications and performance. Only the very early
silver faced amps suffered from engineering changes that made them less
desirable for players as compared to the previous generation of amps."
>The cabinet has 2 Sunn "Guitar Transducers" speakers, 15" each. There are
>2
>small tube ports
>and a wooden "shelf baffle" inside. The back has a 1/4" plug and the 2
>speakers are just in parallel.
>The damn thing had 36 screws in the rear cover plate.
Whose idea is it for 15' guitar speakers? I seem to remember almost as many
screws on my old Orange cabinets, and I was reconing speakers all the time.
In a message dated 10/22/99 8:46:29 PM, jlarryh@... writes:
>in
85 watts is what I remember too. If you are looking for a good single book
for tube amps, then I strongly recommend this one. I got it several years ago
at (the legendary) Mc Cabes Guitar Shop where it was recommended as the best
amp book for a variety of different amps. It's about 750 pages, with about
450 pages (!!!) of different schematics (though almost no text about any
particular amp), I paid about $30 for mine, and I'm sure you can get them
from Antique Electronics in AZ. It is made by the guys who make Groove Tubes
so you get a lot of that stuff too -- sort of free advertising.
If you just want schematics for the Dual Showman, I could photocopy those off
for you (there are a few different schematics, though I don't see any
noticeable difference in general), though in the book they are about half
scale so they might not show up so well on an enlargement.
Yeah, working on your "killer sounding Marshall" under the influence of
"killer lumbo" can get you...well...killed!
>I
>handle.
Yeah, that's from memory, but the 2 ohm output impedance is from the
schematic (2 ohms? What were they thinkin?), as is the parallel speaker
arrangement. So, if that cabinet is 8 ohms that's a fair difference. I've
been using my Deluxe (8 ohm output) for about 20 years with a 12" 16 ohm
Celestion, and I really like the sound of it. But I "recently" received a
Vibro Champ which wasn't working (same guy). After I got it going, it blew
away my other Champ both in terms of volume and tone -- I came to the
conclusion that the Champ I've had for a long time had its 4 ohm speaker
replaced with some type of 8 ohm speaker (apparently this is a common problem
with champs), so there must be somthin to this impedance thing.
Thinkin you should send the cabinet to Larry (to complete his Dual Showman),
and the head to me (as scrap of course), though I don't know what I'd do with
a 2 ohm head.
JB
>  synth1@... writes:
> case. Has Tung-Sol 6L6 output tubes, which means
> about 1967 (!?!). I'll post to rec.whatever and try to
> pin it down.
Well, if they are the original tubes, the date code on the tubes might get
you close.  Back then, tubes didn't sit around on shelves for years.
People used them,  Musicians ABused them.  :)
> From: JWBarlow@...
CBS
early
Hmmm.  My Dual Showman is one of the Silver faced ones.  I wonder how to
tell if I suffer from "early silver face syndrome."  I know I am certainly
suffering from " early solver hair syndrome."
book
ago
best
about
Tubes
off
Thanks. I'll look for the book.
> From: JWBarlow@...
Showman),
with
> a 2 ohm head.
> JB
Reminds me of my favorite stupid impedance matching story.  Back in the
early days (15-16 years old), before any of us long-haired musicians knew
anything about electronics, I was in a pretty decent band.  We just bought
a big new PA system.  The cabinets were 8 ohm 3 way passive crossover EVs
with the folded W bass bins (very nice for the time).  The power amp was
the "you cannot tear up this amp" Sunn Coliseum "slave" head as they were
called in those days.  The guy at the music store had one he used for
demos.  He always started by dropping the head from cabinet height to the
floor.  The cabinet looked like hell, but it always worked when he picked
it up and plugged it in.  Anyway, the rated output for the amp was 2 ohms.
Little did we know that meant 4 or 8 was fine (just less power).  So, since
we only had 2 cabinets, the music store fixed us up with 8 ohm power
resistors at the cabinet connected in parallel.  Ta da, instant fix!!
Hell, we didn't know any better.  We were about 1/2 way through the first
song at the first gig and these resistors are on putting out smoke and fire
(go figure).  So, we disconnected them an finished the gig.  The guy at the
music store assured us we needed to match the impedance or damage the amp
and made us custom "Y" cords each with two 1/4 plugs and one 1/4 jack.  The
two plugs went into the amp and the cabinet plugged into the jack.  Since
each cabinet impedance (8 ohms) now appeared twice at the amp output, we
were officially down to 2 ohms.  Ain't that magic??  We were too stupid to
know any better and used those special "Y" cords for a year before I
learned that we were accomplishing nothing.
Sorry to ramble, but I thought it was funny.
Larry (who dated Mary Jane in High school) Hendry
