Yet more cabinet rail stuff
1999-10-22 by JWBarlow@aol.com
In a message dated 10/20/99 11:06:35 PM, jlarryh@... writes:
>>I then measured the distance between the two
>> edges of the panels which I believe to be about 1/4".
And I don't feel a 1/4" gap to be too bad, but if we use Larry's multi/bus
strips then we have a "different problem" which might alleviate the problem
of the 1/4" gap -- as it stands, I'm really leaning toward using these strips
below each row of MOTM.
>I got a pair of rails from Musician's Friend and experienced about the
>same
>results as JWB.  Like Ken, I was hoping they would allow the modules to
>be
>flush (like the nice ones that Paul makes).  However, they did not, so
>I am
>not certain I am going to use them for that purpose.  I still have room
I agree that I'd prefer the panels to be flush in my system as well, and I
also would agree not to use them for MOTM if Paul had some rails made for
cabinet use -- and it would be great to see him make the strips as well so
they were cosmetically compatible, and use the "official MOTM screw." But I
feel that Paul has his hands full with other stuff and I don't know if
there's enough interest to warrant distracting him. I would imagine that such
rails would be about 24U (like Moe wants) and I'd prefer those to my 21U
rails as well. Anybody else?
JB
Re: Yet more cabinet rail stuff
1999-10-22 by Paul Schreiber
Actually, when I "undig" in about 2 weeks I'll have the sheet metal shop
quote a 12U
"end buttable" rail with the small bend radius used on the 19A rails. These
will have
a wider back flange with countersunk holes for wood screws. You can line
them up
end-to-end as long as your heart's content.
I can't make them longer because:
a) hard to ship
b) I can use the cheap $$$ brake at the shop (they have one that can bend to
76"
but bring money)
The "problem" still remains about a 'double row' system without some flat
board
in-between to screw the rails to.
I could make a long (24U) flat piece with 2 horizontal rows (like 2 19As's
welded together)
and assume that the stiffness of the panels, coupled with screwed-in-wood
top and
bottom rails is sufficient to support 2 rows without "bowing".
To: motm@onelist.com <motm@onelist.com>
Date: Thursday, October 21, 1999 8:16 PM
Subject: [motm] Yet more cabinet rail stuff
>From: JWBarlow@...
strips
>>same
>>be
>>I am
such
>JB
