Rail distance
Rail distance
1999-10-11 by Paul Schreiber
Trying to salvage my dress panels here at 1:30AM.....sigh......
Everyone with a tape measure: please verify that the distance,
center-to-center,
between holes in a 19" rack is 18 1/4". I'm 99% sure this is correct
<<<NOW>>
and that would indicate to me the source of error and probable Barlow scrap
heap.
I might get the machine shop to mill a slot where the hole would be and
touch-up the paint,
cheaper than the $397 I would have to donate to Barlow (and other Stooges).
What I think I did is put the hole 0.275" from the edge of the dress panel
instead of 0.375".
Probably couldn't read my own writing. Good thing I spent all that time in
EE grad school.
can't cypher, banned in 12 states from being within 50 yards of power tools
over 1/2HP
Re: Rail distance
1999-10-11 by Fred Becker
I measure 18-3/8" from center-to-center. That is 18.375". I measured it
on racks from two different vendors and got the same number. Hope this
helps, but it doesn't sound like the answer you wanted.
Fred
Re: Rail distance
1999-10-11 by J. Larry Hendry
> verify that the distance, center-to-center,
My experience has been that this number varies significantly from rack to
rack. Hence the "slots" in rack gear as opposed to holes. I measured
several of mine and find them to be around 18 3/8". However, I have one as
wide as 18 1/2" (Happens to be my MOTM rack). I did not have anything as
close as 18 1/4."
Larry Hendry
