Re: freq shifter knob
2003-01-21 by revtor@aol.com
all,
  I never thought of it that way, but having one pitch control with a big
knob does seem advantageous to a coarse/fine setup in that you can sweep the
full range with just one knob with precision instead of trying to make it
sound smooth using both knobs..  This is a functional reason behind a big
knob and Im all for that..
~Steve M
  Paul, any audio snippets of the week long patch/Useq from NAMM???
RE: [motm] Re: freq shifter knob
2003-01-23 by John Loffink
Exactly!
John Loffink
jloffink@...
big
sweep
> the
it
big
> ~Steve M
2003-01-23 by mate_stubb <mate_stubb@yahoo.com>
I still disagree. Having a honkin big knob doesn't guarantee that the
pot itself is capable of doing the fine control necessary. Trying to
move the pot wiper in smaller and smaller increments causes
mechanical limits to come into play, including backlash, friction on
the wiper, and shaft wobble. You could find yourself unable to zero
in on the 'sweet spot'.
Now if you put a multiturn vernier under the knob, I'd agree with
you. But it would slow you way down doing large manual sweeps. That's
why coarse and fine are a good idea on both a VCO and a freq shifter.
Moe
Exactly!
John Loffink
jloffink@a...
big
sweep
> the
make
it
big
You're thinking of this as a set it and forget it type setting, which is
just one mode.  The other is real time sweeps, wide ranging but with
fine control.
John Loffink
jloffink@...
> Moe
> Exactly!
> John Loffink
> jloffink@a...
> big
> sweep
> > the
> make
> it
> big
Not to forget, my suggestion of a normal MOTM sized coarse tune knob and
an oversized fine tune with a wider than normal range seems to meet both
requests.
John Loffink
jloffink@...
> -----Original Message-----
> From: John Loffink [mailto:jloffink@...]
> Sent: Thursday, January 23, 2003 7:41 AM
> To: mate_stubb@...; motm@yahoogroups.com
> Subject: RE: [motm] Re: freq shifter knob
is
> fine control.
> John Loffink
> jloffink@...
That's
shifter.
> > Moe
> > Exactly!
> > John Loffink
> > jloffink@a...
a
> > big
> > sweep
> > > the
> > make
> > it
a
> > big
> Your use of Yahoo! Groups is subject to
2003-01-24 by elhardt@att.net
John Loffink writes:
just one mode.  The other is real time sweeps, wide ranging but with fine
control.<<
This knob size issue never seems to end.  I'm not sure why a frequency shifter
needs more precision in adjustment or use than all the other modules in a
synth, especially the osc.  If the damn Bode didn't have a huge knob, nobody
would have ever thought they needed one too.
As for real-time sweeps but with fine control, that sounds contradictory.
-Elhardt
2003-01-24 by John Loffink
Why do I get the distinct feeling that everyone who doesn't need the
huge knob has never used a frequency shifter?  Is this just my
imagination?
John Loffink
jloffink@...
which is
fine
> control.<<
> shifter
in a
> nobody
contradictory.
> -Elhardt
This is an interesting point.  At what diameter knob does the fine
resolution become limited by the potentiometer characteristics rather
than the knob size?  I know for certain that it is easier to dial in
sequencer control voltages on my Synthesizers.com sequencers than on a
Serge sequencer.  That's roughly a 2X size difference.  If we go another
2X, does this knob size advantage suddenly become moot?
John Loffink
jloffink@...
> Moe
>>Why do I get the distinct feeling that everyone who doesn't need the huge
knob has never used a frequency shifter?  Is this just my imagination?<<
I don't know.  I have a Doepfer freq shifter.  It only has a single small knob
for frequency, so to me a full sized motm knob + fine tune knob will allow
plenty of room for accuracy when needed, or for fast real-time usage when
needed, without a single ugly huge knob that constantly draws the eye to the
freq shifter module over the synth itself.  But if it were designed with enough
room and long enough tick marks, then people could pop on whatever size knob
they want.  Then everybody can be happy.
-Elhardt
The doepfer FS doesn't really have a fine tuning range.  Its lower limit
is 50 Hz.  That makes a usage comparison to a unit that gets down near 0
Hz difficult.
John Loffink
jloffink@...
small
> knob
allow
when
to
> the
with
> enough
size
> knob
> -Elhardt
Re: [motm] Re: freq shifter knob
2003-01-24 by groovyshaman@snet.net
I think the reason this knob size issue is seemingly endless is because there
are so many opinions - ALL of which are valid - and Tony graciously has
elicited them.  It is also apparent that the human-synth interface is seen as
very important and is something everyone on this list has some experience in,
and therefore opinions on.  Oh, and we have this sea of 1" knobs just screaming
for a 2" one to set things apart. :)
I (unfortunately) have never had the opportunity to fiddle with one of the
"classic" frequency shifters, although I have played with some stomp boxes that
did some similar things.  The only thing I can say from this experience is that
little knobs suck.  But seriously, I can see a very good reason for a single
large knob, as long as it is attached to a TOP quality pot, that would allow
both somewhat-accurate small motions as well as the larger wide sweeps.  I
think having a fine/coarse setup would be more "clunky" in this regard, but
that is just my naive opinion.
So why is it that many of the "classic" frequency shifters that I have seen
have the "single large knob" setup?  (or more likely I just haven't seen that
many!)  Maybe those of you on the list that have used a freq shifter with a
single knob could share your opinions with the rest of us.
George
(don't you love these wacky threads about the size of a knob??)
To: <motm@yahoogroups.com>
Sent: Thursday, January 23, 2003 9:33 PM
> control.<<
shifter
> -Elhardt
2003-01-24 by Mike Marsh <mmarsh@websense.com>
I wonder how much a big knob will move if you blow on it?
Mike
because there
graciously has
is seen as
experience in,
just screaming
one of the
stomp boxes that
experience is that
for a single
would allow
sweeps.  I
regard, but
have seen
haven't seen that
shifter with a
> George
> From: <elhardt@a...>
setting, which is
with fine
> > control.<<
frequency
> shifter
modules in a
knob, nobody
contradictory.
> > -Elhardt
2003-01-25 by Richard Brewster
> Mike
Ok, I read the jokey responses.  But was anyone here ever a ham radio
operator?  Now *there* is a need for coarse/fine frequency tuning.  Mike's
comment reminded me of a knob I became intimate with, many years ago.  No
one mentioned the big tuning knobs used on some of the old radio receivers.
I actually owned one of these:
http://www.qsl.net/ab0cw/nc303.htm
Now there's a big knob!  Next to that huge wheel, low, and to the side
perches a fine tuning knob about 3/8 inch in diameter.  This little machined
knob had a flange for your fingertips, and was merely a gear that engaged
the big wheel to give fine, smooth movement with plenty of control.  A
mechanical engineer's handiwork!  The little knob snapped in for traction
when in use (as well as to keep the big one from moving when you blew on it
;-), and snapped out when you wanted to sweep.  You got the best of both
worlds: a big wheel for smooth, large sweeps, plus the ability to do really
fine tuning.  Admittedly the application is different.  Sweeping a radio
knob is usually to get to another spot quickly, whereas when sweeping a VCO
or frequency shifter, it's the journey that's more important.  (The radio
knob was hooked to a variable capacitor.  How many of you even know what one
of those looked like?  Three-ganged monsters.  That sort of capacitor no
doubt has a finer resolution than an ordinary potentiometer.  The resolution
of a pot attached to such a knob would have to be considered.  Most
fine-resolution pots are multi-turn, which would seem to defeat the sweeping
ablility.)
Such a specialized knob would be expensive or hard to get, I expect.  But it
might find application to synthesizers.
Ok, resume the debate.  This was sort of a side comment.
-Richard Brewster
2003-01-25 by Mike Marsh <mmarsh@websense.com>
I really, truly should have known better.  But I promise it was not
intended as a mean-spirited joke.
I love the uniformity of the MOTM, knob-wise and jack-wise.  But I
also really dig Jurgen's newest synth with that Vernier (sp?) knob.
And full disclosure: the closest I've been to frequency shifter to
the best of my knowledge if the MOTM 110 ring modulator.
So sorry about the post, I'l behave from now on.
Mike
PS - The Brits in the crowd must really be getting a laugh regarding
all this BIG KNOB business.
Oops, I did it again...
m
> > Mike
radio
tuning.  Mike's
ago.  No
receivers.
side
little machined
engaged
control.  A
traction
blew on it
of both
do really
radio
sweeping a VCO
(The radio
know what one
capacitor no
resolution
the sweeping
> ablility.)
expect.  But it
> -Richard Brewster
2003-01-25 by paulhaneberg <phaneber@one.net>
At the risk of beating a long dead horse:
If the frequency shifter is to be in part digital, I assume it would
include a PIC.  The potentiometer could be replaced by an encoder
and the PIC could be programmed to interpret the encoder as a coarse
control when turned quickly and a fine control when turned slowly.
There could even be several scalings all based on the angular
velocity of the knob.  The one large knob could be both the coarse
and fine control.
I have no idea of what this could do to the cost, but possibly you
wouldn't need an encoder and could do the same thing with a pot.
I friend of mine used to run sound for a band I was in.  We used to
feel sorry for him because the band members got the girls and all he
got to do was pack up equipment, so we always told the girls he
wanted a knob job.  Okay, Okay, I know.  But I'm just continuing the
thread.
2003-01-25 by Scott Juskiw
Interesting idea this. We'd need some kind of additional display to
indicate the dialed in frequency shift. At least _I_ would need this
in order to annotate a patch. Tony, are you rolling your eyes at all
this?
>and fine control.
2003-01-26 by Tony Karavidas
>Tony, are you rolling your eyes at all this?
Heh heh, sort of.
Actually I think it's a pretty cool idea, but it will entail more delay
and more cost. I don't know if enough people think it would be worth
that. And you're right, you would need some sort of display to know
where the value is set.
Tony
> From: Scott Juskiw [mailto:scott@...]
> Sent: Saturday, January 25, 2003 1:30 PM
> To: motm@yahoogroups.com
> Subject: [motm] Re: freq shifter knob
> this?
> encoder and
> angular velocity
> >of the knob.  The one large knob could be both the coarse and fine
> >control. I have no idea of what this could do to the cost,
> but possibly
> >you wouldn't need an encoder and could do the same thing with a pot.
