Mod suggestions
1999-02-05 by Dave Bradley
I've been contemplating a couple of mods, and wondered if anyone else has
already thought of these, or maybe has actually done them already.
How about a gate lamp on the EG? The main problem seems to be that real
estate is so tight. Has anyone found a place to put one? Maybe on the VC
delayed EG module (when it comes out), there will be room for both a gate
lamp and a manual gate pushbutton.
On the sample and hold, there is space for an extra jack. I'd like to add an
input that allows you to gate track mode on and off. A slightly more
versatile use would be for a gate signal to reverse whatever mode the
track/hold switch has set. Again, a manual sample pushbutton would be good
for when you want to disconnect the clock or to introduce rhythmic variance.
Dave Bradley
Principal Software Engineer
Engineering Animation, Inc.
daveb@...
Dave Bradley
daveb@...
