Q re: MOTM CV-->Deltalab Effectron (a bit OT)
2003-01-08 by Aaron Day
Greetings everyone-
After years of staring at the front panel of me Deltalab Effectron I finally
took a closer look at the back and realized (duh) that besides in, out,
bypass and repeat jacks there is one labeled "control".
Yep. Running a CV from any number of MOTM modules will in fact vary the
delay time--with interesting and sometimes not so interesting effects.
My questions to anyone who might know the inner workings on the 'tron better
than I:
01 What sort of CV range (in volts) does this device want?
02 Has anyone had luck sampling CV's (with the "hold" feature) and then
playing them *out* of the 'tron to the MOTM. I only seem to get burps and
hiccups (of control).
03 Seems to me this thing is ripe for CV input hacking. Esp into the
"feedback" control. Anyone tried this?
Best,
ad
Receive-Transmit
Aaron Day
aaron@...
Office: +49 030.231.80965
Mobile: +49 179.750.1854
Münzstr 21
Berlin 10178.
Germany
Re: [motm] Q re: MOTM CV-->Deltalab Effectron (a bit OT)
2003-01-08 by media.nai@rcn.com
I haven't played with anything Deltalab in years, but I have other delays
that have CV inputs.  On thing you can do is sync flanging to filter sweeps
and other events with an MOTM-320.
What I haven't been able to do is use the LFO to control a pitch shifter
(PCM80) and a key-tracked patch such that the timbre modulates but the note
remains the same.  I think might be a linear vs. log problem.
I have no idea (how's that for a helpful answer?? :)  However, if my memory
serves me correctly, the Effectron works by changing the speed of its clock
like a BBD delay.  (I wish my SDD-2000 had a CV input.)  Depending on the
initial settings, it could go out of range with a negative voltage.  So I
would try 0 to +5V.
I doubt it could work with its clock stopped.  Afaik, the hold feature is a
tap.  So it essentially plays a short loop of data.  Check to see if the
input is AC-coupled.  If an input voltage was steady enough to work over
the range of a loop, it might not get past the cap.
Someone might have tried.  Does the feedback control use a VCA??  If not,
it is often possible to replace a pot with a vactrol.
