more module construction photos on line
2003-01-07 by J. Larry Hendry
I finally got around to building my Blacet Klang Werk. Of course, I dumped
the Frac Rack format and converted mine to MOTM format on the Klang Werk
panel.  The photos are on line at the link below.  I will have conversion
construction instructions on line soon, along with some neat modifications
for this module.
http://www.wiseguysynth.com/larry/kw2010/2010_construction.htm
MIDI drum controllers
2003-01-09 by media.nai@rcn.com
Well, this isn't all that on-topic, but it's more on-topic than many of the
other posts :)
I'm looking for a MIDI drum controller.  I need something that I can play
with sticks, won't kill my wrists, and doesn't cost a fortune.  I also want
something small that I can mount on a mic stand.  It doesn't have to have
sounds or MIDI inputs.  I just want MIDI outputs with velocity.  Any
suggestions??  I'm thinking of the Roland SPD-6.  Any ideas??
OK :) I'll make this more on-topic.  Has anyone made a PCB that converts
the KADI outputs of a Kenton into triggers that work with MOTM-800's??
Kenton says the KADI outputs are "open collectors" and that one pin is 5VDC
for a "pull up", so I'm thinking they the outputs of most non-op-amp
comparators.  Has anyone put a bunch of S-trigger to gate converters or
inverting circuits on a PCB??
Eventually, my MOTM system will have five to seven VCA's (depending how you
want to count them :) so by using a MIDI drum controller with the Kenton
and a trigger converter, I could have a MOTM drum kit :)
While I realize that I could do that without MIDI, I would also like to use
it with samples and such, and be able to edit my playing with MIDI
sequencing software.
