Re: More about Stooge Walnut Cabinets
2002-12-06 by paulhaneberg
I also have done some serious woodworking. I would agree with the idea of trying to stay away from using solid walnut (or any other solid wood such as cherry) on long pieces. I would use high quality walnut plywood with solid edging. I have a good friend who is a professional woodworker who grew up in Hungary and learned woodworking the old fashioned way. He likes to make cabinets with walnut plywood. He cuts edging material about 1/8" thick on a table saw out of solid walnut and glues it on after making sure the edges are perfectly smooth by using a joiner. He also always uses solid wood for trim, but uses plywood for any large or long pieces such as sides or tops. It can be done using solid pieces, but I'm not sure of the technique. Something to do with gluing together several strips with grain running in opposite directions using biscuits. I also would recommend using hardware which would allow easy knockdown and reassembly. Almost any woodworking catalog has a number of fastening systems which can be used to simplify assembly, but still make an attractive cabinet. Many of these systems use grooved pins and locking cams and can be entirely hidden from the outside of the cabinet. One other thing to all group members, PLEASE be very careful if using a table saw. I have personally seen people get hurt. Cutting 1/8" strips can be done safely, but too often these tools are used in a dangersous manner. I will be the first to admit I have taken shortcuts myself on occasion at the expense of safety. I know a lot of you have made your own cabinets as have I. Please be careful! BTW, I am most interested in seeing what Larry comes up with. Although I have built my own cabinet, I am outgrowing it and it is pretty unwieldy. Although I might start over and build some more cabinest myself, I might also be interested in purchasing a cabinet kit.
