FM Synthesis w/ MOTM
2002-12-03 by matutchiso
Hey MOTM'ers,
I have a 2 osc system with a few filters, e.g.'s and 1 VCA.  So far
I haven't done much FM with my modular b/c from what I understand, I
need a VCA for the modulating signal, and another VCA for the
carrier.  Since I only have 1 VCA, I've been wondering if there are
other ways around this, such as sampling some waveforms from my
VCO's and using the envelopes in my sampler to provide the envelope
for the modulating signal.  Can this work?
Does anyone have any experience working this way or have any
suggestions?
-Matt
RE: [motm] FM Synthesis w/ MOTM
2002-12-03 by mate_stubb
If you have a MOTM-110, you actually have 2 VCAs. The Ring Mod can
also be used as a VCA in a pinch.
Moe
re: [motm] FM Synthesis w/ MOTM
2002-12-04 by elhardt@att.net
Matt writes:
carrier.<<
As pointed out by someone else, you don't need VCA's. I don't have a DX synth,
but I don't remember them having VCA's for their carriers and modulators. Some
of the DX algorithms use a bunch of operators, and that would be a hell of a
lot of envelopes to adjust if they existed.
You may be new to the list, but I posted an MP3 a while back of the MOTM doing
hi-hats and a kettle drum type sound (and a JP-8080 doing low piano notes)
using FM. The pseudo bass/kettle drum sound in the "Lost at Sea" demo is an
example. There isn't always much memory retention on these lists, but I
probably explained the general setup and none used VCA's.  The piano sound I
think used square waves, and the MOTM sounds used sawtooth carriers, sine
modulators, and noise to modulate the modulators.  So depending on the sound,
you don't have to stick with sines.
Larry Hendry writes:
>>Another waveshaping technique that is not FM, but is very cool with a VCA
and single VCO was posted to the list about a year ago by Elhardt I think.
Ken, was that you?<<
Yeah, that was me.  But with a few exceptions, most of those waveforms were
more intesting to look at on an oscilloscope than useful at providing anything
significantly different than the standard OSC waveforms.
Mike March writes:
>>My understanding is that Yamaha FM synthesis is actually using phase
modulation and not frequency modulation.  Am I correct?<<
No. It's called FM, because it's one sine modulating the frequency of another.
Now I see how rumors get started.
Ken Tkacs write:
>>I thought that was Casio that used Phase Modulation...?<<
Either Casio or Technics, I can't remember which. The huge Con Brio digital
synth also did PM.
-Elhardt
Re: [motm] FM Synthesis w/ MOTM
2002-12-04 by J. Larry Hendry
I will agree with that somewhat.  But, I am very appreciative that you
posted that.  What I found is that this method does allow one to do PWM type
sounds with the other waves, not just the standard square wave PWM.
anything
2002-12-04 by J.D. McEachin
The Envelope Generators, LFOs, and other mod sources on a DX would require
VCAs to perform the same functions on an analog synth.
While you don't need a VCA to do FM on a modular, you would want several
to do an FM patch with any complexity.  Remember, with FM, as you increase
the modulator's levels, you increase the carrier's frequency content.
It's a different effect than varying the modulator's frequency or harmonic
content, which is pretty much all you could do without a VCA.
JDM
JDM writes:
content, which is pretty much all you could do without a VCA.<<
Good point. I took the original post about VCA's meaning he wanted to modulate
the levels of modulator with something like an EG or LFO. If all that is needed
is attenuation then the motm mixer can give him a couple of channels of that.
-Elhardt
