Quantizer Question
Quantizer Question
1999-10-03 by Tkacs, Ken
Is there any way of making a quantizer that has a "softness" control? In
other words, there would be an option where the steps are not completely
discreet-the output voltage tends to "pull" the input CV to the quantized
steps, but there is a softer knee?
The reason I ask is that I've always wondered if a quantizer might help make
a Theremin controller a bit easier to manage. But one wouldn't want to
completely lose the Theremin's 'melismatic' nature.
Could it be something as easy as leaking a bit of the input CV into the
output? I guess you could slap an integrator on the quantized output to
force a glide, but that's not the same.
Does any of this make sense?
By the way, regarding microtonality, �-tones are actually pretty nasty. They
just multiply the problems with 12-tone equal temperament by two. If you
want to try a good-sounding, manageable microtonality, try 19-tone ET.
Compared to 12-tone ET, you sacrifice a little bit of accuracy on one or two
intervals, but pick up a lot on the others. You can pretty much map the
chromatic scale onto it with 7 extra notes added.
Re: Quantizer Question
1999-10-03 by JWBarlow@xxx.xxx
I guess you're thinking of something more elaborate than just running it
through a lag processor -- maybe a VC lag processor which is responding to
something like a velocity CV from your initial CV source?
JB
In a message dated 10/3/99 9:22:07 AM, Ken.Tkacs@... writes:
>make
