Re: [motm] transducers
2002-11-08 by nathan durham
>I won't copy and paste everybodies posts to keep from making a mess. I'll just >respond. Larry Hendrey missed the part where I said I wanted to remove a string >and in its place put some kind of device to vibrate the bridge. That would >vibrate at whatever pitch my synthesized waveform is. So matt_stubb and >groovshaman are correct in understanding what I wanted to do. I would need to >keep the other 3 strings there to firmly hold the bridge down, plus in all the >reading I've been doing about the violin, the body tone is a little different >when under the tension of all the strings than without any strings. Without >strings the main formants are lower in pitch. >When I thought of doing this a couple of years back I thought maybe I could >just screw a speaker into the back of a violin body. It's hard to tell if that >would give me any useful results or not. Based on what I've read, the bridge >acts like a lever and where it rests on the violin body and it's internal >structural supports determines where or how strong some of the main resonances >will be. >I'm looking at a small speaker now and there's the possibility if I cut off the >speaker cone I could use the transducer portion of the speaker to vibrate >something. I don't know how I'd mount it to the bridge, but maybe I could >compromise and remove the bridge and strings and mount it where the bridge was. >-Elhardt >The nature of a piezo will not let it produce enough energy. I think you >need something with a coil in it. >To rectify my error, I will report to you that All Electronics has a >"vibrating audio transducer" designed to "make a wall, door or other object >act as a speaker" for $9.00 in their catalog. Check out part # AS-500. >Probably at their web site too. Now, I feel better. >LH Y'all are probably already thinking this but nobody's actually said it, so I will. If you use a speaker in any way, you will always hear the speaker, probably more than the cello or whatever resonant body you are using. It seems to me that what you are looking for is to use the cello not as a reverberant chamber for sound produced by a speaker (it's not big enough for real results), but to use the cello body itself for your speaker. To achieve this, Larry's transducer sounds like a good bet. If it's designed to resonate a door, it should have plenty of amplitude. You could probably mount it anywhere on the cello and get varying results, but if I were to do this, I would start by mounting it on the bridge. If there were a way to do it, I would actually try to mount it so it was pushing down on the bridge, toward the body, so as to emulate the strings as closely as possible. Be aware that each part of the cello plays a part in amplifying the sound of the strings. The bridge has that funny shape because after years of experimentation, the builders found that it was the best design for transferring the resonance of the string to the body of the cello, and the body is designed to optimally amplify vibrations from the specific location of the bridge. Perhaps you could mount the transducer on a surrogate bridge; the most important parts would be the feet, to match the locations of the original feet, and maybe grooves for the strings, to hold it on. I would avoid screwing anything onto the body because it significantly decreases the resonance. The best sound transference occurs when the resonating contact point is under pressure, not held on with screws. Also, as someone else said, watch out for the soundpost inside the body; it's not glued in place, and if you remove the bridge it can fall out, reducing the resonance by more than half and weakening the top of the cello so the tension on the bridge can crush it. When I change the bridge on my bass, I lay it on its back and put a couple of large books near the bridge to keep pressure on the soundpost. Tune the strings according to whether you want string resonance or not (minimal resonance if you tune Eb for a tune in D), or to whatever notes you would want to ring. If you want no string noise, you can put a rubber band loosely around the neck and strings. I would imagine that it would be most effective amplifying music in the natural range of the cello. I've mentioned this before, but I have a book called "Synthesizer Technique" (Hal Leonard HL00183706) which is all reprints of Keyboard Magazine articles from the '70s and '80s, many by Bob Moog, Patrick Gleeson, Roger Powell, and Craig Anderton. Moog has a couple of articles on using filter banks to simulate the resonances of string instrument bodies. ************** >BTW, along those lines. I ran into a guy once who has brass trumpets for his >horn drivers. This was back in the early digital days before good sampling. >He used them to play his brass patches through these. Even though they were >only DX-7 brass patches, they sounded so realistic because the horn >contributed so much to the sound. Very cool idea. The hugest church organs have ranks of trumpet pipes, and when they crank up the sound is terrifying. ***************** >I think this is going about it the wrong way. >More complicated, but more controllable is to get a mechanism to "push & pull" the bow >across a string. Not a regular bow, a small one (say 4 inches). I would do this: >Paul S. Mechanical string instruments such as the hurdy-gurdy don't use bows, they use rotating wheels rubbing on the string. Much easier to control than a bow, and you don't have to worry about running out of bow. Seems like I read something about rosined leather wheels. ****************** >And to expand on this idea a little further: I plan to tune the >strings on the guitar to an open tuning (say, Open D) and then play a >sequence in the same key through the thing. I think the acoustic >drone of the strings will add (if I can believe what I'm hearing in my >head) and incredibly interesting background. I just hope the strings >don't overwhelm the sound from the synth, but we'll see... >Mike >Go play a piano with the sustain pedal depressed. It's essentially the same >thing. Not only to the struck strings sustain, but the rest of the undamped >strings also resonate. In fact, a patent was filed for a reverb system based >on this. I remember reading about the patent just after I'd come up with the >idea myself, probably in the early '80s. >CGS I've got an old piano soundboard with the strings attached; the rest of the piano was hacked off. I love to play sounds into it and listen to the reverberation it generates. I've been thinking of mounting a couple of PZM mics under the strings and using it as an "analog reverb unit". Frank Zappa did a project long ago in which he recorded people talking from inside a piano; he says he actually had them climb into the piano and rap. The idea seems to have been to see how the piano would mutate the conversations. nathan
