Re: OT: Tales from an Audiophiles Crypt
2002-10-29 by paulhaneberg
2002-10-29 by Les Mizzell
2002-10-29 by KA4HJH
>My favourite equipment review fiasco happened a number of years ago whenYou are now preaching to the choir. Boy, do I remember that. I was ROTF.
>Julian Herst decided to debunk the esoteric cable test done in "Audiophile"
>in an another test he performed for "Stereo Review". Anybody remember this
>one?
>In Julian's test, auto jumper cables from K-Mart outperformed every singleThe test I remember (mid-80's) was between 30' of zip cord and Monster
>other cable tested, including those "golden ears only" $450 per meter
>jobbies...
>Nasty letters went back and forth in the two magazines for MONTHS afterMy favorite: "I've experienced a 50% increase in sound quality since using
>that....made for some damn fine reading!
2002-10-29 by Neil Bradley
> The Nyquist criterion states that any sample rate of more than twiceThe Nyquist theorem never stated anything about accuracy, only that to
> the highest frequency is all thats needed for accurate reproduction,
> and I refuse to believe that there are that many engineers who canI hear people state this so often, but the higher sampling rate has
> hear over 20 kHz. I sure can't now and I never could.
> :> and I refuse to believe that there are that many engineers who canYes, it's called "listener fatigue". ;-) Lack of upper band harmonics
> :> hear over 20 kHz. I sure can't now and I never could.
> Isn't there some research to suggest that there is a psycho-acoustic effect
> caused by the "outside" frequencies that ends up affecting the audible
> portion of the material as the different frequencies interact with each
> other?
> cables (2 feet long - he paid close to $500 for them. I don't know what the*DIGTIAL* Transfers? Now I've heard EVERYTHING!
> hell they were!) to make the digital transfers from his DAT master, into my
> workstation for editing and back out to his souped-up DAT machine again. I'd
> have to tear half the studio apart to get it wired *just* the way he wanted.
> He SWORE he could tell the difference....
2002-10-30 by Chris Walcott
Sent: Tuesday, October 29, 2002 3:25 PM
To: motm@yahoogroups.com
Subject: [motm] Re: OT: Tales from an Audiophiles Crypt
Although these individuals had no trouble recognizing the higher
quality of 24 bits over 16 bits, they could not hear an appreciable
difference between the standard 44.1 kHz sample rate used by CDs and
the higher 96 kHz and even 192 kHz sample rates.
I have read some equipment reviews which raved about the improved
quality of higher sample rates, but these were not double blind
studies. Personally I think the reason some higher sample rate
converters sound better is the quality of the filters, not the rate
of conversion. For instance my Apogee Special Edition converters
sound way better than my Digidesign converters both at 44.1 kHz.
2002-10-30 by Tim Walters
> The Nyquist theorem never stated anything about accuracy, only that toAt the risk of spiraling way off-topic, I feel compelled to address this
> reproduce any given frequency, it must be at least half the sample rate.
> If you sampled a 10khz sine wave at 20khz, it would become a square wave
> - certainly NOT accurate. Most filtration in CD players would wind up
> rounding the edges off anyway, but it's still not accurate - as compared
> to the source.
2002-10-30 by Neil Bradley
> > rounding the edges off anyway, but it's still not accurate - as comparedBut if you sampled a 10khz sine and a 10khz square wave, it'll still come
> > to the source.
> very common misunderstanding. The Nyquist Theorem provides the
> mathematical underpinning for *exact* transformation of a continuous
> representation of audio into a discrete representation. If you sample a
> 10kHz sine wave at 20.01kHz, you get a 10kHz sine wave coming back out.
> There are no "edges" to round off, because the digital-to-analog
> reconstruction is not done by connecting the dots.
2002-10-30 by J. Larry Hendry
This reminds me of a clueless individual who thought that buying 5 foot
MIDI cables would have a noticeable effect on MIDI delay over 10 foot
cables. Little did this individual know that for even a single sample @
44.1khz delay to be induced by the wire it'd have to be about 2800 feet
long. ;-)
-->Neil
2002-10-30 by Tony Karavidas
Sent: Tuesday, October 29, 2002 4:18 PM
To: MOTM-l (E-mail)
Subject: RE: [motm] Re: OT: Tales from an Audiophiles CryptIn the November issue of Electronic Musician there is an article on "Bridging the 96k Gap". Very interesting article. The thing that struck me was that two highly regarded engineers (can't remember their names) said that there very little difference between a track recorded entirely at 24/96 from a track that was recorded at 24/48 and upsampled to 24/96.For me this is good news as I'm not about to upgrade my studio to support 96k. The cost would be enourmous. Instead I can buy a stereo 24/96 interface (edirol makes a usb one for under $300, MOTU makes one for about a grand) for monitoring and do my pre-mastering at 96k in the DAW.- chris-----Original Message-----
> But if you sampled a 10khz sine and a 10khz square wave, it'll stillThis is just another way of saying that the maximum frequency represented
> come out exactly the same.
> Having a higher sampling rate will yieldIf the human ear can't hear anything above 20kHz, then it makes no
> better/closer to the original results, which was the point of the
> original post IIRC.
> > But if you sampled a 10khz sine and a 10khz square wave, it'll stillThat's already a given, and you missed my point anyway. If you sample a
> is 10kHz.
> > Having a higher sampling rate will yieldIt does if the original sampled sound isn't a square wave.
> > original post IIRC.
> difference at all if a 15kHz square wave looks better on the scope sampled
> at 96kHz. (It'll only look a little better, anyway.)
> I don't really have a strong opinion about whether 96kHz sounds betterI don't know what "statement" you're referring to, other than the quality
> than 44.1, except in the context of audio processing. I just didn't agree
> with your statement about the Nyquist theorem.
2002-10-30 by J.D. McEachin
> If the human ear can't hear anything above 20kHz, then it makes noAnd there's the rub. Most people CAN distinguish between high frequency
> That's already a given, and you missed my point anyway. If you sample aNo, you get a 10kHz SINE wave, due to the reconstruction filter following
> sine wave @ 20Khz and a square wave @ 20khz, you will only get a 10khz
> square wave when you go D to A.
> > That's already a given, and you missed my point anyway. If you sample aGood catch - very true. Let's reverse my statement - if you sample a 10khz
> the DAC. That is, IF the filter is ideal, as specified by Nyquist.
>That's already a given, and you missed my point anyway. If you sample aNo, it won't. That's the whole point of the Nyquist theorem.
>square wave when you go D to A. The sine wave will lose detail.
>I don't know what "statement" you're referring to, other than the qualityThat would be it.
>of the waveform has zip to do with the Nyquist Theorem.
>And there's the rub. Most people CAN distinguish between high frequencyThat's because most people who try it use a sine and triangle with
>sines and triangles, even though the harmonics of the triangle are above
>the range of their hearing.
> Ultrasonic components have an effect onThey use difference tones to derive audible frequencies from
>perception, even if they can't be heard. Further proof of this is the
>"audio spotlight" that delivers audio using ultrasonics (see
>holosonics.com).
>The question is, how high do you need to go to accurately reproduce aGamelans and crash cymbals go up into the MHz, IIRC.
>performance? Horns are the acoustic instruments that produce the most
>ultrasonics, and they don't do much past 50kHz.
> >That's already a given, and you missed my point anyway. If you sample aMisstated example - Replace "sine wave" with "square wave". The square
> Everything below the Nyquist frequency is reproduced *exactly* (given
> ideal filters etc.). A 20kHz sine wave is just as detailed when
> sampled at 44.1kHz as when sampled at 96kHz; either way, it contains
> all the information of the original wave.
> The only thing increasing the sample rate does is allow you toAnd represent the original waveshape better provided it's not a sine wave.
> represent higher frequencies (and possibly to design a better
> real-world filter).
> > The only thing increasing the sample rate does is allow you toNot in any way except by representing higher frequencies.
>> real-world filter).
> >> represent higher frequencies (and possibly to design a betterYes, and what you're stating is incorrect. ;-)
> >> real-world filter).
> Weren't we just here?
>Yes, and what you're stating is incorrect. ;-)Nope. :)
>If I have a 20khz sample rate, and I have the following waveforms beingFirst of all, you need >2x, not 2x. So say 20.01 kHz. No perfect
>sampled (assuming PERFECT alignment of the sample point and the peaks of
>each cycle of each waveform):
>10Khz Sine waveWhich is a perfect representation of the <= 10kHz component of each wave.
>10Khz Square wave
>10Khz Sawtooth wave
>10Khz Pulse wave
>When played back at the same 20khz sample rate, they are *ALL* going to be
>sine waves (assuming an ideal filter, of course).
>The peaks from theOf course. The high-frequency information is missing.
>sawtooth wave are now rounded.
>Now let's assume a 40khz sample rate with the same 10Khz signals above.They will now be perfect representations of the <= 20kHz component of
>Each waveform looks quite a bit closer to its original.
>Therefore, aNope. The representation of the <= 10kHz components is identical.
>higher sample rate == higher detail at the same original input frequency.
>If you double the sample rate, you double the significant samples within aIf you want to use "detail" to mean additional high-frequency
>waveform, making it closer to the original. Hopefully this clears it up
>100%.
>How about taking this to:I guess that answers my question. I'll stop now.
>digital.stuff.rec.boring
>ZZZZzzzzz....
> Gamelans and crash cymbals go up into the MHz, IIRC.I guess I blotted that memory out. I had dog ears when I was younger, and
Cc: <motm@yahoogroups.com>
Sent: Tuesday, October 29, 2002 11:53 PM
Subject: Re: [motm] Re: OT: Tales from an Audiophiles Crypt
> >> real-world filter).
wave.
10Khz Sine wave
10Khz Square wave
10Khz Sawtooth wave
10Khz Pulse wave
sine waves (assuming an ideal filter, of course). The peaks from the
Each waveform looks quite a bit closer to its original. Therefore, a
100%.
-->Neil
Neil Bradley In the land of the blind, the one eyed man is not
Synthcom Systems, Inc. king - he's a prisoner.
ICQ #29402898
2002-10-30 by Sikorsky
> jobbies...
hello all,
of course you can also use wet string to transmit audio - i think Canfords
did this at their stall at a recent AES in Amsterdam
this and other daft techniques have yet to be tested - though i did try the
setting-fire-to-a-speaker-for-a-low-pass-filter-effect
cheers
paul b
2002-11-04 by sucrosemusic
sample a
10khz
(given
contains
> real-world filter).
quality
> That would be it.
> Tim Walters : The Doubtful Palace : http://www.doubtfulpalace.com
2002-11-04 by media.nai@rcn.com
>So, really, I think you need at lesat 192k. Can you hear the
>difference? Hell if I know, but at least the data is THERE.
>Filtering off at 20k is just a hack. It's lame. I'd like to have a
>system with NO filtering. Not likely, sure, but imagine a sampling
>rate so high that at 20k, even drawing everything SQUARE your sound
>would be so high rez that you couldn't tell. THAT's what i'm talking
>about, yeah, yeah.
2002-11-04 by paulhaneberg
