RE: Moogerfooger CV pedal
1999-09-28 by joe.pavone
I bought a few MoogerFooger EP1 expression pedals and they are "ok" quality - all "tough" plastic. Easily modified, if the price does not scare you ($40) then try one...
see:
http://www.bigbriar.com/moogerfoogerproducts.htm
...jp
_______________________________________________________________________________
see:
...jp
>From: motm@onelist.com on Tue, Sep 28, 1999 11:35 AM
>Subject: Re: [motm] CV pedal
>To: motm@onelist.com
>From: thebass <thebass@...>
>Can't you get expression pedals from Moog? The Threamin Moog, not the "new
>Moog".
>"J. Larry Hendry" wrote:
>> From: "J. Larry Hendry" <jlarryh@...>
>> The Yamaha FC-7 pedal is the one I use for ALL my control at gigs. These
>> are great pedals that last forever. And, they are completely rubber coated
>> -- no slip, no noise. I use them mostly for volume control (MIDI-wise), so
>> they get bounced around quite a bit. They have this cool feature that lets
>> you adjust the travel range for a standing or seated position. They have a
>> nice long throw too. HIGHLY recommended.
>> Larry H.
>> > From: "Paul Schreiber" <synth1@...>
>> > There are 2 easy-to-find "expression" pedals: Roland EV-x series and
>> Yamaha
>> > FC-x.
>> > These use TRS 1/4" plugs. In typical fashion, they are *not* pin-for-pin
>> > compatible.
